Which valley cover and coolant crossover pipes for carb'd LS1?
Carbing a 2004 GTO crate motor (new, never installed) using an Edelbrock Performer RPM manifold. I won't be running knock sensors so I need to plug the holes somehow or run an aftermarket valley cover. Which one do most run?
1. Get a LS2 and cut the back part?
2. Edelbrock's one made for carb'd LS1/LS6
3. Other?
Which coolant cross-over pipes are most running? Will the LS1 one that links all 4 ports fit under the manifold? If not, are most just running the LS6 set up at the front ports?
Thanks,
Brian
EDIT - Ended up with the Edelbrock LS1/LS6 valley cover and the older-style 4-port coolant pipe. See pics below.
3. Other?
Thanks,
Brian
The LS2 one with the PCV vent is suppose to be the better way to vent the crankcase. That is what I have. Not sure why you would have to cut the back part. I just have the front head vents.
Do you have a LS1/6 block? The cam position sensor is at the top rear. I think the LS2 valley covers this up. LS2s gave the cam sensor on the front of the engine.
This is a track motor so venting from the valve covers will work fine.
Yes, I have an LS2. There is a write up on here on how to convert an LS1 to an LS6 valley cover. A pretty common upgrade.
Just make sure you use a catch can. The valve cover vents tend to put oil into the intake. That is why GM moved them.
Yeah the LS2 cover won't work with the LS1/6 due to the cam position sensor. The LS1 to LS6 "conversion" is only needed if you have an earlier LS1. You have to trim a small amount out of the valley area and of course change the coolant pipes if you're running the injection manifold.
The 2004 GTO LS1 I have already has a LS6 PCV system on it. And yes we run catch cans. We vent the valve covers to a breather can and cap all the other stuff.
Some light massaging and I was able to get the old-style LS1 coolant pipe to fit. Figured I'd post up for anyone searching this same stuff. FWIW the Edelbrock valley cover is needlessly thick in the center. If I had use a basic 1/8" piece of plate aluminum I wouldn't have had to massage anything to get it to fit.
Not wanting to force the manifold on I kept massaging the coolant pipe until the manifold sat perfectly flush on the heads w/o any gaskets in place. After I got that right I installed it.
