which carb jets should i start with
parts are piling up and i'm starting to look into the smaller things. this is my first carb setup to touch EVER aside from my weed whacker :noob:
the setup:
stock bottom LS2
TEA Trick-Flow 225 heads (61cc)
1 7/8 longtubes
236/242 .112/.112 110LSA 106 ICL
vic Jr intake
Holley 750 DP
what is a good safe starting point?
the setup:
stock bottom LS2
1 7/8 longtubes
vic Jr intake
Holley 750 DP
This is the resource that I use to see all of the factory calibration and components for Holley Carburetors. http://www.holley.com/data/TechServi...%20Listing.pdf
And, please change your avatar so I don't have to poke my own eyes out!
awesome. i'll probably start on the street to get it close, then really work the suspension/timing at the track. that is if i can get the motivation to start wrenching in this heat. it's hot as ***** outside. i dont have all of the parts yet either.
is this what you're talking about? if so it may be what i have....i need to learn more about this carb that i have. i'll post numbers and pictures later. maybe you guys can help me figure out if i got something worth a crap or not.
http://www.holley.com/134-300S.asp
Yeah thats what I what i was talking about. I liked how mine ran after adding that to my 4779-9 carb. I read somewhere that it increases the flow to around 780. The jets it came with were pretty close for my cam only 6.0, but I tried 2 sizes bigger and it seemed to like it.
750 street is fine, but of he wants max power, a larger pure may do, we have seen 6.0 built lose time with a swap from a 750 to a larger piece, Matt in his third gen can tell you, every combo has its wants and needs.
I still havent opened the carb to see what jets are in there. it's getting close to starting time though.
