Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
MSD red wire
Old Aug 17, 2012 | 07:02 AM
dmracing's Avatar
Default MSD red wire
I have the MSD 6012. What did you guys run the red power wire to. I was going to run a relay from the battery, triggered by the ignition switch.
Old Aug 17, 2012 | 01:56 PM
massen1981's Avatar
thats what I do, works great
Old Aug 17, 2012 | 07:06 PM
S10xGN's Avatar
According to MSD, it's supposed to be wired directly to the battery...
Old Aug 17, 2012 | 07:34 PM
dmracing's Avatar
I understand that, just just wondering how you turned it on/off
Old Aug 17, 2012 | 07:41 PM
S10xGN's Avatar
The point is, you don't "turn it off", there's another wire for that. Have you looked at the wiring diagram that came with it? If you don't have one, they can be DL'ed from the MSD site.
Old Aug 17, 2012 | 09:03 PM
dmracing's Avatar
Theres only 3 loose wires. red, yellow, and the grounds.
Old Aug 17, 2012 | 09:23 PM
S10xGN's Avatar
You're right! I must have been thinking of the old 6-AL series. Should work direct to a 12v keyed source or through a relay, either way...
Old Aug 17, 2012 | 10:56 PM
Prorac1's Avatar
Yeah, your thinking of the old 6AL series. I just wired one of those this last weekend and it had a keyed hot and a constant battery hot. My MSD 6012 is just like his, with a red, yellow and a ground. Eric L
Old Aug 18, 2012 | 09:22 AM
toxic99's Avatar
In my 67, I had to find a keyed hot that stayed hot even in the start position. At first I had it on a keyed hot that went dead in start pos and car wouldnt start, obviously, then I checked to make sure there wasnt a battery specific wire and a keyed hot wire on it via instructions and that's when i figured out there was only one hot.
Old Aug 19, 2012 | 09:18 PM
96t/acj's Avatar
run a rely... point blank!
