Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
FYI for Performer RPM users!!
Old 11-27-2012, 09:40 AM
kstafford's Avatar
Default FYI for Performer RPM users!!
Recently I set up a motor with a Vic jr manifold the one that is pre drilled and tapped for the msd ing box and after getting very pissed of trying to get my 750 do to idle correctly I realized the hole front and center is drilled right through the intake runner WTF! Not a huge deal but it would be nice if it said in the directions somewhere that this needed to be plugged if you don't want to mount your msd box in that dumbass position! I feel better....
Old 11-27-2012, 09:44 AM
Pop N Wood's Avatar
Unfortunately you are not the first one to notice that.
Old 11-27-2012, 10:01 AM
kstafford's Avatar
If I can save just one fellow from this travisdy my job is complete. I also called edelbrock and told them to smart the ŁĄ€$ up!!!!!!
Old 11-27-2012, 10:18 AM
Old School Heavy
speedtigger's Avatar
My Victor Jr. does not have a mounting spot for the MSD box. Did the early models have that? I know my Performer RPM had the mounting for it.
Old 11-27-2012, 11:58 AM
hifi875's Avatar
Yep it sure does make a difference when you plug that hole on a perf rpm!!!!
Old 11-27-2012, 04:53 PM
kstafford's Avatar
You are correct sir my bad i changed the title it is indeed a Performer RPM.
Old 11-27-2012, 06:38 PM
In-Zane Moderator
ZONES89RS's Avatar
They got me too, but just for a second. Went from a Vic jr to a RPM, then put my finger over the hole....I thought "no way they would have a hole straight through, right?".
Wrong. Lol
Old 11-27-2012, 08:32 PM
Beeterolds's Avatar
Happened to me too, I spend $$ on plug wires thinking they were the fault.. Plugged the hole and bam, motor runs like a top again
Old 11-27-2012, 09:23 PM
snyousef's Avatar
Got the same manifold, thanks for the heads up I have to remember to plug it!
Old 11-29-2012, 02:56 PM
kstafford's Avatar
Default So much fun
Between the hole up front on the intake, The bung in the back that i used for the Map sensor was leaking a little also. I removed my brand new holley 750 dp while troubleshooting and some how knocked my seconday return spring off is perch oviously not helping me set my idle. Top all that off with two brand new plugwires with "thoses cute little fiberglass socks" yeah they melted inside the sock and shorting to the headders!!!!!!WTF!!!!!!!!!!!!!!
In other news i think i picked up about 150 horse power on the butt dyno!
Old 11-29-2012, 03:06 PM
cruisin'73's Avatar
Default Job complete!
Jeeze, that is unbelievable crap! You probably just saved me a whole lot of frustration! I'll go home and check my intake tonight. Thanks Kstafford!
Old 11-29-2012, 04:11 PM
In-Zane Moderator
ZONES89RS's Avatar
I used a screw for mounting the MSD box by the way.
Old 11-29-2012, 06:07 PM
Polynikes's Avatar
I was also one that found out the hard way. Zone, that's exactly what I did too.
Old 11-29-2012, 06:44 PM
snyousef's Avatar
Looks like I'll just mount the MSD in that spot...
Old 11-29-2012, 07:45 PM
wildcamaro's Avatar
Never noticed that on mine, helps that I mounted box on the intake though...I can't believe there is no note of the through hole in the intake! Good post!
Old 11-30-2012, 06:31 AM
In-Zane Moderator
ZONES89RS's Avatar
Note that the Holley will not clear a msd ignition mounted there without a spacer. It was designed for clearing a square bore edelbrock carb.
Old 11-30-2012, 07:50 PM
87caprice318's Avatar
hmmmm i just covered that hole and the sound of the car doesnt change at all
Quick Reply: FYI for Performer RPM users!!
