99 Z28 + L76 + Nitrous
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
Tell me what you think I can get out of my car with this setup I just acquired
99 Camaro Z28
Converted to TH350 from 6 speed
4.10 rear gear
26x10 MT ET Streets but going to radials
07 L76 out of Vortec Max truck
Aluminum block with 364 heads
Cam swap with a range of .630 or more
Going carb intake with 750 Holley and a fogger nitrous system with progressive system
Questions
How much power can be had on just horsepower?
Nitrous shot of progressed 250 shot is possible?
Have seen sideways carb setup will it clear stock hood?
Shelf stock cam or custom grind one?
99 Camaro Z28
4.10 rear gear
Questions
being looking at a lunati 60521 or 60522 camshaft
.651/.651 with 108 CL
powerband 3200-7200 for the first
powerband 3600-7500 for the second
leaning more on the second cam because of the powerband and more in line with a 3500 stall
I saw where the XR281HR .571/.573 cam with l92 heads and a 10.0:1 6.0 made 551HP
So I thinking with a bigger cam like the 60522 would make alot more power then the above camshaft and plus its a carb design camshaft
