Expert Carburetor Advice needed, video of issue
So i got tired of screwing around with fuel injection and decided to go blow through. rebuilt a holley 650 double pumper and slapped it on the victor jr. and every time i try to rev it it wants to backfire through the carb. i thought it may have been getting too much of a accelerator pump shot so i moved the cam around one hole to lessen the initial squirt but that didnt seem to help. i am lost and looking for advice on where to start looking for the problem. it has 66 main and 67 secondary jets, a 6.5" powervalve and a powervalve plug in the rear. what am i missing on why the carb is doing this?
i also just realized that when i was snapping the throttle open that it was falling on its face like it wasnt getting enough fuel from the accel. pump until the main metering system kicked in and started delivering fuel...
http://s155.photobucket.com/albums/s...=VIDEO0010.mp4
ill check the plugs tomorrow, i have the timing set a 20* btdc from 0-1500 steps down to 18 from 1500-3000 and 15* 3000-redline this is approximate since i dont have the timing map in front of me.
should i add more main jet? i really dont think its lean...
what is the hollow screw youre talking about? and the timing is just to get a baseline and get things running well enough to where i can drive it and tune with a wideband. i do have a 6.5" powervalve in the main metering block. maybe ill try a plug and step up the jets tomorrow.
Your 1st post said the secondary side had a PV plug, therefore the secondary side jets should be increased 6 sizes minimum. The hollow screw is for the squirter nozzle so it won't get starved out. Throw some more timing on it and see what happens, most guys here are running between 30° - 36°...
