Trying to get 500hp out of my LQ4.....
Decided to go LS in my 84 Cutlass. I got a 6.0 from an 02 Denali. Upon reading up on these I see that they were rated at 320 hp and the 6.0's from the Escalades were rated at 345hp. With a few upgrades my goal is to hit 500hp on the engine dyno......How can I accomplish this??
This is a street/show car that see the track every once in a while for fun.
I plan on keeping the bottom end stock. I have so far:
MSD box
Edlebrock Performer intake
Holley HP 750 carb
317 heads milled .30
Holley blue electric fuel pump
The cam I've been considering is the Comp Cam 54-448-11 with lift .605"/.609".
2800 stall in 200r4 trans.
3:73 rear end
29' tall rim/tire
Any input/info is appreciated.
I still need springs, lifters, rockers, push rods, timing set, oil pump
MSD box
Holley HP 750 carb
3:73 rear end
29' tall rim/tire
You need about another 1k rpm on the stall too IMO. Pretty easy to get to 500 flywheel horsepower. Ported stock heads and a descent cam is all you need with the carb setup
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Old School Heavy
MSD box
Holley HP 750 carb
3:73 rear end
29' tall rim/tire
MSD box
Holley HP 750 carb
3:73 rear end
29' tall rim/tire
The combination of too much cam, low compression and smallish torque converter will be sluggish in the low RPM ranges.
If you want to make 500 on a stock bottom end, you will need much more camshaft, a really nice set of ported heads, and the victor jr. intake manifold at LEAST.
Also like others said, minimum 3500 stall speed converter.
Think of how aggressive you want this engine to be before you commit to stock bottom end.. A stroker motor with a mild cam will be much easier to do then a cam only engine with a real aggressive cam.
MSD box
Holley HP 750 carb
3:73 rear end
29' tall rim/tire
MSD box
Holley HP 750 carb
3:73 rear end
29' tall rim/tire
