Changed direction on project.
I won't have to money to complete my turbo this winter so no I am going to be putting the boat back together with cam only. I was told that my cam wasn't all that good for a turbo anyways. I also need suggestions for pushrods, springs, and if this cam will have any clearance problems.
This is a gen iv 5.3
799 heads
1-5/8" sprint car longtubes
750 Holley sitting on a Vic jr.
Cam card
What kind of power and torque do you think it'll make at the flywheel?
What kind of springs? I do plan on going blow through in the future so I'd like to spend the money once.
What length pushrods will I need? Hardened?
Thanks
As for valve springs, I like my PAC 1518s. They are nitrided for extra durability which would likely be a good idea in your boat where you will have sustained high RPM. If you have not milled the heads and that cam has a base circle about .030" smaller than the factory cam like a lot of aftermarket LS hydraulic rollers, then a 7.4 hardened pushrod should work. But, the right thing to do is to measure it with a pushrod length checker tool.
Below 3000 rpm I'm not moving. Once on plane, 3500 should be about 35 mph give or take. Then the boat pops up on a air pocket after about 50. I really would like more rpm so the powerband you posted sounds really nice. I'll look at your recommended parts. Should I use the stock lifters and rockers?
The standard upgrade from most everyone on this site is to install a trunion upgrade kit on the rocker arms. Most guys on here have used the Comp Cams kit, but I have been hearing that some are using a new kit from Summit. Harland Sharp also sells a kit with a good reputation.
