My 86 Notch Carbed LQ9 Swap.....
#41
seperate tank, seperate fuel pump?
#43
Got some good new's and some bad also.....
Good:
Motor is together
MSD box was mounted
Harness ran
Shifter mounted
Dzus fastener's done
Bad:
While unbolting the trans to toss in the JW 4000 stall I picked up for cheap, found the bellhousing was cracked/broken!
So now it's either I send the current trans out to JW and have them Ultra bell it, or just find another th400 to toss in it!
I will load the pics tomm. for you guys!
Good:
Motor is together
MSD box was mounted
Harness ran
Shifter mounted
Bad:
#46
Got a decent amount of stuff done today!
Got the trans situation fixed and yanked the motor back out to slap the converter/trans in, also routed the trans lines/routed fuel lines/plugged the harness in/made mounts and put the rad and fan in and got the hoses done!
Header flanges are finally here so those will get done this weekend!
Thing's on the "to do list"
Make crossmember
Mount fuel pump
Weld the header flanges
Wire the car up (lights etc.)
Have driveshaft made
Here's some pics:
Make crossmember
Mount fuel pump
Here's some pics:
#56
The interior of my car is HORRIBLE!
Eventually I will do a VFN dash, going to find some door panels for it and maybe even a center console to make it look a little better, for now I just wanna drive it!
