cam what u guys think of this cam ???
Howards, Hydraulic Roller Cam, Chev Gen III LS-Series 3-Bolt
Chev Gen III LS-Series 3-Bolt 1997-Present
Advertised Duration: 281/284
Duration @ .050": 226/232
Valve Lift w/1.70 Rockers: .578/587
Lobe Separation Angle: 112
Intake Centerline: 108
Valve Lash: Hyd./Hyd.
2000-7200. Aggressive street/strip, upper torque & horsepower. Needs good heads.
4 this set up
5.3
241 W/PAC 1218
EDDY RPM
750-800 DP
1.3/4 HEADERS
350 TRANS W,3500 STALL
4.10 GEARS
150 shot
IN A 79 MALIBU
4 this set up
5.3
241 W/PAC 1218
EDDY RPM
750-800 DP
1.3/4 HEADERS
4.10 GEARS
150 shot
IN A 79 MALIBU
In-Zane Moderator
Because of the 112 LSA, no. Give the SNS stage 1 from tick a try. Specific for us carbed guys. Should work spot on with your combination. The bit of extra lift will take the max advantage of the heads flow.
http://www.tickperformance.com/tick-...1-ls6-engines/
And if you want it as aggressive as the cam you posted, the stage 2:
Would increase your operating range to just over 6500.
Old School Heavy
4 this set up
5.3
241 W/PAC 1218
EDDY RPM
750-800 DP
1.3/4 HEADERS
4.10 GEARS
150 shot
IN A 79 MALIBU
4 this set up
5.3
241 W/PAC 1218
EDDY RPM
750-800 DP
1.3/4 HEADERS
4.10 GEARS
150 shot
IN A 79 MALIBU
I normally use my Elite Series cams for just about everything and very rarely do custom grinds anymore, but with a carb set-up if at all possible I like to squeeze some more overlap out of them by tightening the LSA up. It really helps broaden the torque curve and give the cam more of a mid-range punch. We could do one in this case, but the TM Stage 1 or 2 would be just fine as well.
The TM Stage 2 already has 10.5* of overlap so it's pretty much perfect for a 5.3 in that regards, but if we could squeeze an extra 2-3 degrees in there it's only going to strengthen the torque curve.
