Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
what gear to run?
Old Apr 7, 2013 | 10:01 PM
79nova's Avatar
Default what gear to run?
what gear should I run? I have stock 2004 4.8 with edelbrock rpm intake and controller, with quick fuel slayer 600cfm, 7004rwith 2200 stall with holley exhaust manfolds, going in to a 1978 nova, has stock 2.73 gears
Old Apr 7, 2013 | 10:11 PM
89gmcs15's Avatar
What do you want to do with the car? What's it weigh? What size tire?
Old Apr 7, 2013 | 10:19 PM
79nova's Avatar
around 3400pds and tires are 27 inchs tall, many a street car
Old Apr 7, 2013 | 10:27 PM
ZONES89RS's Avatar
In-Zane Moderator
A stock 2200 will work. If you want more of a launch, a 2800. If you go cammed, things change again. But 2800 is the max with a 2.73 gear.
Old Apr 7, 2013 | 11:25 PM
89gmcs15's Avatar
If you wanna cruise down the highway I'd run 3.73 gears. Your 2.73 will be too low with the torque of the 4.8 engine to move your car at highway speeds. I punched the nbers into the calculator and 3.73 gears will run you at 2300 at 70 mph. With your 2.73 gears you'll be runnin too low. Wallace racing calculators ( http://www.wallaceracing.com/gear-speed.php ) will let you figure out your rpms. I think 4.10's might be too high for ya but then again it all depends on how much highway you drive with your car. Play with the calculator but don't forget your other gears too.
Old Apr 7, 2013 | 11:52 PM
ZONES89RS's Avatar
In-Zane Moderator
3.42 to 3.73 is great for the street. I dont know what i read earlier with my converter reply.
Old Apr 8, 2013 | 05:16 AM
Pop N Wood's Avatar
My 6.0L in a 2500# car turns 2300 RPM at 70 MPH. I could use more gear. So I like 89gmcs15's suggestion of 3.73 gears. Should be just right for the heavier car and slightly less displacement.
Old Apr 8, 2013 | 04:13 PM
Doug G's Avatar
I miss my 2.73's...but didn't have OD....since you do, I agree with Zone and Pop (mid 3's would be great)
