lsx 454 cam in 6.0?
Cool,its good to know someone else is building one. I was getting nervous about this ,Im not gonna be in a huge hurry to screw this motor together cause my car is running good now. The pressure is getting to me.lol...
i just got that cam to go in a super budget alloy 6.0, with LS3 heads shaved 100 thou ~12.0:1, leaving the ports stock, running vic jnr and getting a horsepower innovations e85 carb, plus running a dizzy. will need some decent flycuts.
specs are actually
236/246, 600/600 with 1.7 rocker (635/635 with lsx 1.8), 110 lsa.
think its really going to go well.
specs are actually
cam has been checked and with 1.7 rocker is actually on average 611-613 lift.
only need 60/70 thou fly-cuts even with the 100 thou off heads. overall coming along really well. hopefully not too far off.
Dogballs, I'm sure it will run hard with the compression you have in it combined with the squareport heads, mine ran great with a similar combo.
sbmalibu, yours will run good too, but I recomend holding out for the right heads, do not put LS1 heads on it
Thanks for the input three pedals. Its gonna get a set of 243 heads ported by rich grogh. He is my buddys engine builder and head porter for his mean street car. He has designed a couple of cnc porting programs for other shops that sell cnc heads. This is part of the reason im taking so long.And I cant wait to hear how yours runs dogsballs.
[QUOTE=dogsballs;17541815]some updates with this.
[/QUO
what did you make the cuts with?
[/QUO
flycuts done with cutting tool, pretty much a valve with serrations on the bottom.
need to mill a fraction on the inlet face of heads (so can use the manifold for other engines). although could get away if the inlet port o-rings were thicker.
#32
Well no updates so far on mine. It tooka side burner to other projects and is just getting ready to start buying parts again. I am shopping for a set of heads to get ported by rgr just need intake and pushrods once we finalize heads to put this deal together. But its also -6 outside and we have our 2nd big snowstorm and ice storm of the year and its keeping me from wanting to run the heater in the garage too much so progress is slow. LOL
#33
car running great, yday ran best 10.08@133.6 with 1.48 60ft (134.4 and 1.45 best), at ~2800lb with t350 and 3.45. making power to 7200 rpm, using e85 carb.
#34
Your motor was a flattop ls3 or relief l99 I can get l99 pistons but wanted the flattops, when you milled your heads .100 what was their cc then from 70cc, where you shifting that motor??
#35
alloy 6.0 with flat top pistons.
58cc with 100th removed.
peaks at 7200-7300, when we tried 7500 rev pill in the msd 7al3. but for safety put 7300 pill and shift 7100-7200.
