L-33 carb'd build up (lots of pics inside)
#42
Great deal if the carb is to big would be counter productive... IMO
So...750...which one, there are half a dozen different versions now-a-days.
Use to be.... vac. 2nd or double pump... miss the old days.
Quick fuel also makes the same in a 780 cfm ?
Sorry so many questions guys.
#43
Old School Heavy
Two models from Quick Fuel to consider. The SS series if you want a choke or the Q Series if you want max performance:
http://www.quickfueltechnology.com/c...50-cfm-ms.html
http://www.quickfueltechnology.com/c...-cfm-drag.html
Also, if you are on a budget, the Holley brand 750 "Street" HP is a great carb, but it does not have a billet base plate or metering blocks. I think the Quick Fuel is worth the extra money, but here is the Holley:
http://www.summitracing.com/parts/hly-0-82751/overview/
#46
Here is my build thread: https://ls1tech.com/forums/conversio...r-project.html
It's also in my Signature link.
#48
I just carbed an L33 and since I didn't have the cash for an aftermarket cam I just threw in a stock corvette cam which gave me some extra duration and lift...with an edelbrock performer intake, Holley 750, and stock manifolds with x pipe and flowmaster the car hauls ***! It makes bangin gears in my 4 speed manual tons of fun! It blows up the 14" wheels I have lol...good choice in motor, the 10:1 compression, ls6 heads, and all aluminum construction are a real advantage! Pm me if you need any help!
I'm going to put the biggest cam I can fit in mine. My car has manual brakes so vacuum isn't an issue. What transmission are you using and how had it held up?
#49
I'm building an LH6 (4th gen aluminum 5.3) and bolting it up to a super T10 4 speed. Did you use a hydraulic clutch or manual linkage? I'd really like to use my manual linkage but I have concerns about finding headers that will work. Ok was a welder for almost 10 years so I could make them work but if I could find some ready to rock that would be great.
