First time start. Absolutley no OIL PRESSURE
#44
[QUOTE=Punisher_ws7;17581318]im going this route
your local oreillys has a version of this in the rental tools.... like 174.00 but soon as your done 100% of your money back[/QUOTE
This would be alot easier. But I've got the balancer back off already. I'm gonna call them and see if the y
Got one.
Got one.
#45
Did you crank it without the plugs after packing it, or just start it up? Wonder if I could just pull the front cover and take the front off the oil pump and pack it on the crank without taking the pickup tube off and dropping the oil pan. I have to take every bolt completely out of the pan to get mine to drop far enough because I have a Lakewood bellhousing and a crossmember that I built. They won't let it tilt down far enough to get the pickup tube bolt out
#48
We got it. Thanks for the help. Heres what I done. Took the new pump back off. Was gonna take it apart and pack it with vaseline but the melling pump has torx 30 that hold the cover on. Must have been put on by the hand of god because 2 came out easy and I stripped 2 trying to get them out. Decided that getting the other 3 out would be impossible, I just packed it and rotated it as I packed it til it squirted out the pressure side. Put it back on. Cranked it about 6 or 7 seconds with the plugs out and boom, 40 LBS of pressure. Im gonna go back out in a few minutes and fire it back up and see what happens. Thanks to fast89stangfor the idea.
