Tuning issues.... Vacuum???
5.3 short block
243's shaved .030, w/3* valve job
comp 223/228 @.5 601/617" 112lsa
Vic Jr.
holley 750dp (68p-73s) with a 6.5pv and a blue cam
6010 with all in @34* by 2700
700r4 shift kit (no stall yet)
and 3.23s out back
The only thing I havnt tried yet is a bigger squirter and thats just cuase the speed shop is closed till monday for vacation..
So any thoughts, ideas, long shots at this point I'll chase down... even maybe just to hear a few other similar setups carb settings and maybe tweak from there..Thanks everyone! I hope to get this thing tuned so I can finish with the spray setup and see what she'll do.. Everyone at the track keeps harassing me, but no one wants to help! So now I just want to show them all up!
Take the carb off and look at the baseplste by the secondary shaft, you will see a small flat head screw going through the baseplate and touching the idle cam deal on the secondary shaft. Now turn that screw in which in turn opens the secondary shaft. You want to open the secondaries enough to square off the transfer slots. After you get this set adjust the primary shaft idle back some if not all of the way closed. Id bet money you have a ton of transfer slot showing on the primaries from using it to set the idle and it is flooding out the motor.
Id set all of the throttle cams, pump cams, squirters,etc back to stock also i dont think that is your problem. Make sure your accel pump linkages are set to where once you barely crack tbe throttle they start moving the arm, there is a clearance spec thst holley gives to use a feeler gauge to set them but i dont remembr what it is off the top of my head and ive always just set them with just a hair of a gap at idle.
I had a built 327 in my nova with a huge cam that only made 7 inches of vac at idle and i ran a pretty much stock 650 double pumper with mechanical secondaries and it ran awesome.
Disconnect your brake booster if you think its leaking.
