Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Your thoughts....
Old 08-25-2013 | 07:40 PM
Doug G's Avatar
Default Your thoughts....
When I had my motor rebuilt, I talked to the machinist about nitrous (150 shot max) and he gapped the rings for it....then I hear about the fly-cut stock pistons with N2O isn't the best idea.
So....up in the air IF it'll get sprayed or not....maybe a 100 shot...IDK
Do you think my rings are too loose and letting compression pressurize the motor which caused my dip stick tube to spray oil ?
Only "venting" the motor had was a single 3/8" line from the drivers side valve cover to the rear of carb. Pass. side valve cover is capped.
Or what other ideas you think it could be ??
I was told to do a leak down test.
I did add a big ricer looking breather to the oil fill cap, but haven't been back out.
Old 08-25-2013 | 08:31 PM
snook's Avatar
Let it breathe some more??? id try a bigger filter the oil cap, a non ricer one, lol. I don't get any spray from the one in the valley, but my motor is just cammed and basically stock. Sounds like yours is makin a lot of pressure
Old 08-25-2013 | 08:43 PM
Doug G's Avatar
That breather on the oil cap is pretty close to what I have...LOL
I drilled a hole in the cap, used a 1" NPT threaded brass hose barb.
Old 08-25-2013 | 09:03 PM
snook's Avatar
I thought you meant one of those small triangle cone ricey ones, that should be enough, I just thougt Id try the valley plate. I got a small round one on the tube of the valve cover too.
Old 08-25-2013 | 10:20 PM
3pedals's Avatar
post a pic of your engine Doug, the way you described it in your first post sounds like the engine has no breathing at all, but then you mension a breather in the pass side vc, oil cap? I agree to let it breath! but I am not a fan of venting the valley cover, as when I tryed that it sprayed oil VERY BAD
Did the machine shop say how deep they flycut the pistons? because I cut mine .070"ish, and the releif is no where near the edge of the piston, I would not be afraid of sprayin some NO2 on them at all.
Old 08-26-2013 | 04:48 AM
ZONES89RS's Avatar
In-Zane Moderator
My lq4 has oil in several places under the hood, I need to see what's the issue. Has PCV and the small 20$ filter on the passenger valve cover. Gotta spray it all down and see where it's coming from.
I say if you did not cut more than .050 on the piston a 150 shot should be ok.
Old 08-26-2013 | 06:54 PM
Doug G's Avatar
I'd have to look at the paperwork again.... .624 lift,.050 cut, and .100 I/E (or maybe that was the clearances ??? LQ4 w/ LS3 heads and stock bottom end)
Old 08-26-2013 | 07:07 PM
Doug G's Avatar
Barrett, yes had NO breather, just a PCV line to carb.....NOW has breather like the pic above in oil fill cap only and still the 3/8" PCV line.
Old 08-26-2013 | 08:14 PM
speedtigger's Avatar
Old School Heavy
Well, take it out and run the hell out of it now that it has the breather and see if it huffs oil.
Old 08-26-2013 | 09:23 PM
jgillen91's Avatar
i use the same style breather on the valve cover as this one. i always zip tie a rag around it. usded to have to change it every other track day started to get a lil saturated. after i started spraying nitrous through the motor, i havent had to change it once lol 12 bottles ran through it 150-275hp levels. maybe you should spray it a lil lol worked for me
Old 08-27-2013 | 05:31 AM
Doug G's Avatar
I really have to....but 6-7 day work week is killing me....no fun time
Old 08-27-2013 | 08:10 AM
3pedals's Avatar
I hear you, I have a new baby girl that is getting all my attention. But soon enough it will come
Old 08-27-2013 | 03:14 PM
TXsilverado's Avatar
i've cut my stock ls2 pistons .090 and plan to spray atleast a 200.
Old 08-27-2013 | 05:42 PM
89gmcs15's Avatar
I cut my stock ls2 pistons just over .070 but mines cut for ls3 heads so its close to the edge. I hope it holds a 100
Old 08-27-2013 | 05:53 PM
Old School Heavy
I hate it when work gets in the way of my hobbies.
Old 08-27-2013 | 08:12 PM
Doug G's Avatar
Holiday weekend coming.....she'll get out an stretch her legs some on a back road somewhere
Testing he he
Old 08-27-2013 | 08:30 PM
3pedals's Avatar
AHHH, I love trips to deserted mexican roads, LOL!
Old 08-27-2013 | 08:52 PM
Old School Heavy
LOL! That's a long drive for you Barrett.
Old 08-27-2013 | 08:55 PM
Doug G's Avatar
It is too....eh ? lol
Old 08-27-2013 | 09:00 PM
3pedals's Avatar
Hahaha, I think here's a road called Mexico closer than you think.......
Quick Reply: Your thoughts....
