fusible link ???
fusible link ???
My hot wire from my alternator stood came loose and shut my car down in the room yesterday.. try to start it I got nothin no power to anything hieadlights still work but no power to fuel pump or nothing??? how do I check the fusible link if its the problem how do I fix ???
A blown fusible link is just like cutting the wire. Use a test light. Turn the key on, start at the battery and just keep working your way down the line checking each connection until you find where the voltage stops.
Check your fuses first. Some of those might have tripped when the wire came off the stood.
Once you find it replacing a fusible link is easy. Just cut it out and splice in a new one. Or better yet, replace it with an in line fuse.
