Visit to the track
This was the best run, a Lincoln with a coyote swap 5.0 and a shot of gas. Pretty sleeper if you ask me!
It is the trex and it was supposed to be a Revmax 4500 converter. It is too tight. Foot brakes 2300.
So 1.55 60'...that's impressive with a tight converter. What all have you done out back? Are you running stock axle shafts? Any mods to your rear suspension?
I just got done swapping from a glide to a TH400 w/brake & FTI 4000. I'm a running a mostly stock LS1 (cam/carb) with all stock rear suspension and stock axle shafts. Hoosier 275/50 DR's & 3.73 gear...I'm hoping to get my 2900lb fox in the high 1.5's and hoping my axle shaft can live till winter when I can afford to upgrade.
