edelbrok vs NOS nitrous jetting
Put a Eddy performer nitrous kit on a buddies 65 Mustang. Its the small kit adjustable from 50-75-100. Well on motor it traps 111. Turn the bottle on and went 124.99. That's a huge gain! Anyone else see gains like this? Is the eddy kit 100 rwhp or crank? Another buddy same day sprayed 150 and only picked up about 7 mph. The cars were about 1000 diff in weight. His was a NOS brand.
A low compression car with a big cam and a tight stall converter will pick up far more than a well optimized N/A cam with a loose converter. Then there is jetting and timing and all the other stuff.
I have also noticed that Edelbrock kits suggest bigger jetting per HP level. For example, my NOS Cheater plate says a 63n jet is a 150 shot while an Edelbrock Performer RPM nitrous kit says a 150 shot is a 68 jet.
Thsnks Speedtigger. The car is pretty optimized on the motor.It runs 11.91 at 111.8 so its pretty efficient. The bottle I think loves the 3.55's where as on motor would prefer more gear.
Yeah that digital window switch is cool. Depending on track conditions can play with it in 100 rpm increments. On a good track prep day will bring it in earlier and see how the tires will hold.
