Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Blowthrough 6.0 S480 5speed combo
Old 05-19-2014, 10:54 PM
  #61
silverls1z28ofdeath's Avatar
It's pry already been stated but what is driveability like with these turbo blow throughs and what about transitioning also in the carb?
Old 05-20-2014, 07:07 AM
  #62
3pedals's Avatar
No driveability issues with carb at all. This CSU carb is awesome.
It has boost referenced power valves which bring the extra fuel in with boost.
My datalogs from a pass show the A/F starting at 11.4 at the launch, and creeping slightly to 11.8 at finish line. I actaully blame my water/meth kit for that, as it operates on a hobs switch and flow is constant.
Old 05-23-2014, 02:14 PM
  #63
bdr
bdr's Avatar
NICE! Do you have more pics of the manifold setup? I'm going to do the same thing with my truck manifolds.
Old 05-24-2014, 09:00 PM
  #64
3pedals's Avatar
Here are a few pics of the manifolds. Tough to see exactly how I modded them, but check em out anyway.
Old 05-29-2014, 08:53 PM
  #65
smokin91rs's Avatar
i have a 69 camaro i flipped the drivers side up and forward and the pass side is down and forward. hey 3 pedals im interested in your carb setup i bought a csu after fighting my homebrewd 800. anyway i had a lean transition problem and what finally fixed it was opening the secondarys 1:1 with the primaries. it had a lean transition so bad it back fired threw the carb and i ended up bending a rod. with the old carb and the csu until tried the 1:1 then it ran mint. but i only have one csu brpv . kevin set the carb up with a standard pv in the front and brpv in the rear but the boost holds a standard pv closed. main reason i bought the csu. just curious if your runnning two brpv or not i have a ly6(6.0 with l92 heads 9.5:1) with a 215 230 ls7 cam. 750 csu carb. intercooled no meth. and a older garrett t6 flanged tv7511 turbo with a 80mm compressor wheel.
Old 05-29-2014, 09:14 PM
  #66
3pedals's Avatar
my CSU has a regular PV in the primarys, and a boost referenced PV in the secondarys. It was a bit lean on tip in as well, but some larger squirters fixed it for me. I have a wideband to help tune, so I could see that it went lean with throttle movement, and then recovered with steady throttle, indicating the shooter size was where I should make a change.
Old 05-29-2014, 10:54 PM
  #67
Chris05's Avatar
Dayummmm! That's awesome congrats on the E.T.
Old 05-30-2014, 07:09 AM
  #68
3pedals's Avatar
Thanks.
I'm on a mission to go 8's with stock bottom end and a stick shift
Quick Reply: Blowthrough 6.0 S480 5speed combo
