asked for a cam spec and wound up totally confused
#61
Stamp I feel you on the street1st/track2nd talk. I plan to stay away from being a trailer queen unless its a far track like dinwiddie or further. So a torquey motor with pretty good HP will work for me. If I can get 11 anything next year on motor I'd be extremley happy and very satisfied.
#62
Also keep in mind roller cams give you options the average first gen didn't have.
#63
Not being able to hook at low RPM is a good argument for trading low RPM grunt for high RPM power. In other words a bigger cam and single plane intake. Then all you need to do is gear it right and you have the best of both worlds.
#64
I never said anything about only being able to make big peak power or have to spin 7,000 rpm. That is the myth of the single plane that I am trying to dispel.
My whole post was to be taken that you can have dual plane low end power, and single plane high end power put together if you take the proper steps to a LS3/L92 head combo.
My post was taken out of context as single plane does not automatically mean no power down low and only peak hp.
Read this thread:
https://ls1tech.com/forums/generatio...70-update.html
This can be done with LS3 heads. The cam just has to be proportional to the combination.
He went from a longer runner intake than a dual plane(will make more torque) to a single plane Super Victor and with the proper cam he lost NO power under the curve at all. Torque curve matched his Fast intake torque curve to 5000rpm where the Super Victor pulled away.
In fact, the new cam was bigger than the old one! It had more overlap too! Impossible you say? I think not.
It can be done if willing to take the proper steps.
Read this thread:
#65
That is a great argument as long as you stall it tight so you don't get to the meat of the torque curve too quickly from a stop. But my question to you is, have you ever owned a car with a lot of cam, but with a tight converter? They pretty much suck at everything except going fast "after" you finally get to the power band. No fun at all, down low ,where you drive a street car 90% of the time.
#66
Read this thread:
Read this thread:
Im still in for a true comparison between the LS3 dual plane and vic jr with cams optimized for each. Its just a shame that a well designed intake is getting ignored , or bad mouthed by some, when no one but D&A has done any real work with it, and found it to make better average #s than the single plane. The same open minded thinking that figured out how to make great low end #s with a single plane would be a great thing for a study with the dual plane. After all, open minded thinking and good old hotrod ingenuity is what got us to where we are today, making more power than we could have imagined 20 years ago.
#67
The whole point of my post, is if you do it right, you can have your cake and eat it to. Not to bash a dual plane intake or shun a good part that makes good power. The myth that good power can't be made down low with a single plane was the only meaning of my post.
Of course the new cam he has now wouldn't be optimal for the Fast intake. The point I'm making here is a well optimized set-up will beat out a set-up that is not all day long. Most if not all single plane set-ups I see on this site are not optimized which is where the results and data came from that you will lose torque with a single plane over a longer runner intake manifold.
With a dual plane, and the length of its runners and runner lay-out it's just not possible to do both where you can make big power up top and down low. Can respectable power be made? Damn right! I just prefer a single plane with the cam timing events I've found to work optimally.
If the cam is proportionate to the induction system and size of the engine the results will be good.
#68
Fair enough. Just for comparison, what different would you do with the cam profile if the runners of an intake were a third again as long as a Vic Jr, and had huge runners with cross section as big as the runners on an LS3 head? Am I loosing top end power because of the route the individual runner take to their head port? Or is it the length of the runner? Im just trying to understand why the dual in its particular app, with huge ports and good runner length would give up at upper rpms (6500-6800) compared to a single plane. Im not arguing , just trying to understand. In this case Im speaking on a 376cid engine, not a stroker 416-427, that would need quite a bit more air flow at higher RPM.
#69
I'm kinda curious to what rpm the dual plane is efficient up to to find a cam that gives those rpms the power they need. I'd be fine shifting @ 6500 if the power is felt throughtout.
#70
Even though you say yo prefer single plane cam layout ,because of your familiarity with it obviously, with a DUAL PLANE TORQUE BUILD with LS3 heads. What might you consider an optimal setup. (Can pm me or email me back)
#74
The dual plane is in no way a bandaid. It is a great STREET intake. Average power will be up in almost all cases. Average power is what a true street car is all about. My little street car has great power everywhere in the rev range with those big, high RPM heads. If we are to believe its a waste of time to have anything but a single plane carb intake, there sure are a lot of "lucky" plastic intake guys running around on this site! Just think about the statement you just made. Bandaid? I respect you and what you did with that 68, but Im calling BS on your last statement. I hope there is no hard feelings, brother.
#75
So there we have it
Street = dual plane
Strip = single plane
Everything else like cams, heads, exhaust, displacement, rotary, piston ,V8, V6, I4 and fuel type is derived from this one universal truth.
I never knew hot rodding was so simple.
Street = dual plane
#76
Wow, Pop, did I say that? I sure didn't mean to. I did say you shouldn't make a blanket statement that anything other than a single plane is a waste of time and a bandaid to crutch poor low end performance on the rec. port head. Of the three LS based engines I have owned, the LS3 in my 72 Camaro is the best at overall punch, from idle to redline. The other 2 were cathedral port engines.
#77
Newschool72 I like your point of views in regards to this dual plane option. Your keeping me in the dual plane corner 4 sure
I kinda don't think anybody would create a product tht performs less than what's currently out and it performs worse and sell it for more. Ijs
If the ls3 dual plane is anything like what I imagine my current gen1 dual plane to be like. It looks like it would b a raised floor where its feeding 4 cylinders quicker than the other 4. . . I can't explain it so well but (again I'm young forgive me 4 my ignorance). But someone will get what I'm saying.
Splitting the incoming air/fuel charge to make up for. . . I don't know I can't get 2 much into it cuz I'm @ work. Ill get on later if I need tobfinish
#78
Am i the only one reading Martin's posts?
cliff notes:
with the right cam, the down low torque/power curve of a dual plane and the plastic intakes can be matched with a single plane intake, but around 5,000 rpm the single plane intake will continue to make more power while the others begin to taper off.
your argument "but i dont want to pull my car to 7,500 rpm"
my argument "fine. shift out early before peak and still make more power in wherever range you decided to shift"
now try to convince martin why he should spend boatloads of money investigating an intake that he can match the performance of down low, and exceed up high with a single plane???
cliff notes:
#80
cliff notes:
martin can match the down low torque/power curve of a dual plane and the plastic intakes with a single plane intake, but around 5,000 rpm the single plane intake will continue to make more power while the others begin to taper off.
now explain 1 perk of the dual plane and convince martin why he should spend boatloads of money investigating an intake that he can match the performance of down low, and exceed up high with a single plane???
cliff notes:
