asked for a cam spec and wound up totally confused
I asked a well known Ls1tech member for a can spec that would it my build. And the answer he responder with confused me alot.
I told him I'm building a Lsx, ls3 heads, VICTOR JR, TH350,3.42 gears and would like to avoid flycutting/notching pistons.
He responded : the only issue with single plane intakes and ls3 heads is ptv clearance. There is no room for the camshaft to scavenge the intake opening and exhaust closing events to properly scavenge the intake runner and produce torque on par with that of a long runner intake manifold.
????what????
There are big people running Victor jrs that haven't flycut their pistons and are running decently. Then i asked if switching to a dual plane instead of the single (since I haven't purchased the upper half of the motor yet). But since its taking him about 3days in between to answer I thought I'd ask the broad majority.
When I sent the same specs to TSP they speced me a 235/239 can and said ptv clearance would be fine. . @
I'm just confuser now.
????what????
If your not drag racing your vehicle all the time a dual plane is the way to go. The single only shines over the dual after 6500+ rpm. If I did mine again I get a set of good proted cathedrals a dual plane and enjoy the low end grunt. Mine doesn't open up untill 5500. It pulls hard down low too but I'd gain with a different setup
If your bit drag racing your vehicle all the time a dual plane is the way to go. The single only shines over the dual after 6500+ rpm. If I did mine again I get a set of good proted cathedral a dual plane and enjoy the low end grunt. Mine doesn't open up untill 5500. It pulls hard down low too but I'd gain with a different setup
I'm setting mine up to b a MONSTER
Old School Heavy
I told him I'm building a 6.0, ls3 heads, VICTOR JR, TH350,3.42 gears and would like to avoid flycutting/notching pistons.
????what????
????what????
Common sense tells me the "bit" is supposed to be "not". B is beside N on the keyboard, and I is beside O as well. Just like the "can" spec in your first sentence the N is beside the M on the keyboard.
I agree, dual plane for the street, single for the strip
I knew you would say that, lol It doesn't make sense to me to run a single plane on a 6500 rpm motor, the dual plane will make more all the way to that rpm usually. A true street car will benefit more from a dual plane imo. But opinions are like ********, so pick what you think will suit your needs
Old School Heavy
I understand that, and totally agree, but I still say a true street car will benefit from a dual plane. To me a street car guy doesn't worry about all that stuff. Maybe I should call it a cruiser instead of a street car, sorry for the derail, Ill shut up now
Don't have an intake centerline but 235/239 .639/.623 available in 112 Lea or wider. The techee specd me to go 112. The only thing about this can I didn't really like was there aren't to many ppl with drive experiences. I don't want to get it and it has terrible driveability everywhere under 3,000 rpm. . But its the only one I've been specs so far
AND THATS WITH THE SINGLE PLANE AND A STATED NO PTV CLEARANCE ISSUES.
Old School Heavy
I think this is it:
http://www.tickperformance.com/tick-...1-ls6-engines/
If you care about drivability and want to stay with the 3600 converter, you should get a cam like 3 pedals used to run. He had a 227/235 LSL custom Comp Cam. I think he ran 10s on that cam in his 67 Camaro. Martin at Tick sells a cam just like that and lots of guys have had great dealings with him.
I think this is it:
I think this is it:
lol, driveability issues under 3000 rpm with those cams, yep they are big suckers for 4000+ convertors. imho will be ok around town with tight convertor, but will want to rev. with the square port heads you don't really need to a lot of cam to make them go. i've found compression and good fuel make a bigger difference. heck i ran a stock Ls2 cam on a 6.0 with ls3 heads (just milled 100thou) and ran e85 and punched 400rwhp.
i'd be looking at 210's or even 220 cams, with a 30thou off the heads, still will have plenty of ptv.
Old School Heavy
https://ls1tech.com/forums/forced-in...275-build.html
Here is a thread on his current personal buid. Send him a PM.
Martin@tick is the person I mentioned that confused me about the ptv and single plane. Is it him? He must b a busy Guy cuz he takes days to respond.
I'm 22 so I may b a little impatient, so ill try to chillax .. but who to pm?
