Crank wear??
there both between these caps like if there gringind with the caps or debri was in there idk spins good with no problems shoukd i be worried? there was no shavings in oil pan
Crow bar ima check again today have a buddy coming over we might just tear it down I really didn't want to cause I was just gunna put heads and cam and use this motor for a couple months till she blew then build a 6.0 on the side
So I took a better look and it looks like the main caps have little pieces of metal stiling out the bottom causing it to scratch it u think it'll cause a big problem later on? Just want to get this thing running already
