throttle is sticking some ???
#45
Old School Heavy
Then I suspect your pump shot is not lasting long enough. If you have 40 squirters front and rear and the cars leaves, then bogs - yet it does not bog from a roll, I am going to say I think you need a 50cc front pump.
If the above is correct, and you agree, you will need to order a 50cc front pump kit and the 50cc front pump cam. Don't forget the 50cc specific pump cam.
#46
#48
I think you need to take a step back and check the carb from the ground up. Lots of links telling you how to set up a carb for the first time. Put a big enough shot on there and it will get you through the WTFO test, but it will also mask whatever else is wrong and buck and stumble under normal driving.
#49
Old School Heavy
Have a look at this image of the Holley pump cam assortment:
The 50cc pump cam is brown. If you look closely, you will see it is taller than the others. You need the brown cam.
http://www.ebay.com/itm/Holley-Narro...-/170478745719
#50
I see that a lot. People put on the big pump and don't put on the taller cam. Without the taller cam, the bigger pump does nothing.
#58
With the 50cc pump & blue cam there's still a little stumble but nothing like it was... waiting on brown,cam to get here...running about 50mph and floor it.it will bog all most out ??? Too much gas or not enough gas ??? 72 front & 80 back ??? what cam should i have in the back ?? I have pink on it now...
#59
Old School Heavy
