Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Going Carb'd
Old 10-26-2013, 11:39 PM
mr haney's Avatar
Default Going Carb'd
Monday I will begin my quest to install a carb'd 5.3 in my 98 TransAm. I am sure there will be obstacles to overcome but it will happen. The motor is a stock 5.3 with a Tsunami cam, springs,etc. It has been VERY low 10's in a first gen Camaro with a 100 shot. My goal is a 9 sec car that I can drive anywhere. We'll see what happens. Will post pics and time slips as progress is made.
Old 10-27-2013, 12:19 AM
In-Zane Moderator
ZONES89RS's Avatar
Glide Trans right? What gears you using?
Old 10-27-2013, 02:21 PM
mr haney's Avatar
Yes. Going with a glide. I have a rear end out of an SLP Camaro, It has 3.42 gears with an Auburn posi unit. We'll see how that gear works out. More of a trial than anything else. If I like that gear or wish I had more, I am going to go with a 9" with whatever gear I feel I need.
Old 10-27-2013, 03:31 PM
In-Zane Moderator
ZONES89RS's Avatar
The steep gear in the glide and 3.42s won't work too well being down on torque. Will do great cruising though.
Old 10-27-2013, 08:52 PM
mr haney's Avatar
I know it's not the best but it's what I have. I plan to get it running and the bugs worked out of it first. Then I will go with a better rear end, probably a 9". May even go with mini tubs, narrow the rear and get some fat skin under it. And hey, I can always leave on a little more spray to compensate!
Old 10-27-2013, 09:58 PM
In-Zane Moderator
ZONES89RS's Avatar
Any current pics?
Old 10-28-2013, 08:14 PM
mr haney's Avatar
I was out of town today. Swap will start tomorrow. Will post a few "before" pics tomorrow. We did look at the cowl real close this evening. I think that since all I have to clear is the carb, we can limit the trimming as much as possible and then install a 1/4 to 1/2" metal "lip" at the opening created in the cowl to make it functional. I think this will route any rain to the remaining plastic cowl, preventing water reaching the caRB.
Old 10-29-2013, 03:07 AM
In-Zane Moderator
ZONES89RS's Avatar
If I didn't get this mustang, I would probably have ended up with a 93-95 LT1 body with the 98-02 front end and carb swapped it with a LS K member. Still want to do one actually.
Old 11-05-2013, 08:42 PM
mr haney's Avatar
I've had the motor out for a few days now. First time removing engine from an F body. Pretty straight forward. I would guess that next time it would be a 2 hour job start to finish. Got all the an fittings and hose in to plumb the fuel lines along with the Areomotive regulator. Carb will ne here tomorrow. Once I get the motor in, I will need exhaust and lengthen the drive shaft. Should be moving in a day or do. Also, had to have the block drilled and tapped for an alternator mounting hole that the 5.3 block didn't have. I will post some pics when I figure out how to load them to new laptop from phone.
Old 11-08-2013, 08:01 PM
mr haney's Avatar
Swapped oil pan off the LS1 for clearance. Swapped out pulleys so accessories will work. Got the alt hole drilled and tapped. Carb came in and if all goes well will have pics of cowl trimming and motor install soon.
Old 11-09-2013, 12:34 PM
CayenneRedV6's Avatar
Awesome. In for pics.
Old 11-23-2013, 11:17 PM
mr haney's Avatar
Update. Cranked the motor tonight. Problem with fuel system though. The return line actually runs to the evap canister. This causes an odd looking fitting that has wires plugged to it to puke gas like all hell. It is located above rear end attached to under side of body. Looking at posts related to bypassing canister.
Old 11-24-2013, 01:05 PM
In-Zane Moderator
ZONES89RS's Avatar
You used the wrong one. There is another that is a bypass return. The other is for the charcoal canister.
Old 11-24-2013, 08:02 PM
mr haney's Avatar
Two lines under hood. One is supply. The other one is not return line? Please tell me what you know!!
Old 11-24-2013, 10:17 PM
silverls1z28ofdeath's Avatar
There is no return that runs to engine bay on a 4th gen just the evap and feed
Old 11-25-2013, 05:15 PM
mr haney's Avatar
I know that.....now. I guess I have to bypass canister. or did you run a separate return line? If so, where at tank did you hook it up?
Old 12-02-2013, 07:34 AM
Did you ever get this figured out?
Old 12-02-2013, 07:52 AM
mr haney's Avatar
Yes. The second line under hood goes to the canister located in fenderwell behind rear tire on driver's side. I will either run an 8 an return line to tank connected with a bulkhead fitting (most likely) or use the line that goes to canister and re-route it to tank, bypassing canister.
Old 12-03-2013, 12:09 PM
In all the posts I've read about doing this to a 4th gen no one has ever made mention of what to do with the fuel lines. I was hoping someone who's done it would chime in and help you. The EVAP canister isn't really needed right? If it's like older cars it's just an emissions thing. Not having to run new fuel lines would be nice... So where is the return line if the second line under the hood is for the EVAP canister?
Old 12-03-2013, 01:06 PM
newschool72's Avatar
Im not completely understanding why you would go to all the trouble to run a return line for low pressure carb setup. Is it because you are looking to use the factory EFI in tank pump? Knock a hole in the lower part of the fuel tank, install a bung for the fuel line and get a low pressure carb fuel pump . Dead head it to the carb and run like the wind ,bullseye !
Quick Reply: Going Carb'd
