Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
squirter size
Old 11-21-2013 | 05:25 PM
fast89stang's Avatar
mines pretty rich after the burnout when I clean it out, but when it leaves, no black smoke to speak of.
Old 11-21-2013 | 05:32 PM
Doug G's Avatar
Maybe I should ask Santa for an SV-1 ?
Now back to reality....
Need to take a closer look at what I have....and make it work.
Old 11-21-2013 | 05:34 PM
speedtigger's Avatar
Old School Heavy
Originally Posted by fast89stang
My jets are actually 98 square, no power valve front or rear, squirters are 45, with a 50cc on the frt. I wonder if there is benefit of going with a 50 on the rear? I dont know if it is or not. I stopped at 98 jets cause thats all I had, but mph picked up around 1 mph over the 95s
What carb are you using such a large jet in? Are you running alcohol?
Old 11-21-2013 | 08:24 PM
ZONES89RS's Avatar
In-Zane Moderator
Just got a text from him:
"Pump worked! Giggidy!"
Lol
Old 11-21-2013 | 09:03 PM
Doug G's Avatar
Lol
details man
Old 11-21-2013 | 09:24 PM
ZONES89RS's Avatar
In-Zane Moderator
He sent a idle and rev video. Before it was cutting out and now the pump shot is making it come to life.
Old 11-21-2013 | 09:55 PM
950 ultra hp. I was even told by jmarkaudio on yb to block all pv and start at 95, he said these new ultras don't have a very good signal. I run pump gas.
Old 11-21-2013 | 10:06 PM
Old School Heavy
If anyone would know, it would be him or Yeti.
Old 11-21-2013 | 11:33 PM
TXsilverado's Avatar
pump worked wonders. before, if I barely tipped in, it would ****, backfire, and die if I held it there.
got a kit, but didn't use the arm that came with the kit because the squirter wouldn't shoot as soon as I cracked the primary. not sure what was up with that, but I kept the arm that was on my 30cc pump.
I found out that I have a 50cc pump on the secondary....didn't know that lol. so now I have a 50cc on the primary with the brown cam, and a 50cc on the secondary with a pink cam.
my question...is there any reason to change the secondary back to a 30cc???? if it has a pink cam with either diaphragm, it seems like the pink cam would push the exact amount of fuel no matter which accelerator pump was used. teach me something! i'm coming from the EFI world and this carb stuff is exciting to me. all I did was back the idle screws on each corner out 1.5 turns, set the float and cranked it. cant wait to get my wideband on this thing. it's loaned out to a buddy now while he tunes his magnacharged ls2.
here is a quick vid
Old 11-21-2013 | 11:46 PM
Originally Posted by speedtigger
I wanted to note the the 50CC pump does not have the same effect as increasing the discharge nozzle size. It will increase the pressure of the shot slightly and it makes the pump shot duration last longer.
I'd be willing to try this method too...I have a wideband, and this stuff is new and fun at this point. just gotta figure out what the hell a discharge nozzle is
yesterday I didn't know what a accelerator pump was, or how to set the float/pump arms.....anything basically. I just knew I had a carb that didn't work lol. at this point I need the easy cheap fixes that will get it running damn good. once I get the basics i'd be more than willing to dive into the fine tuning aspect of carbs. at this point the 50cc pump did the trick perfectly.
Old 11-22-2013 | 04:57 AM
jaywill's Avatar
good info..
Old 11-22-2013 | 06:15 AM
  #32
Pop N Wood's Avatar
Well hopefully once you get the wideband on there and tune the intermediate circuits it will allow you to take the 50 cc pump and big squirters back off.
Old 11-22-2013 | 07:03 AM
  #33
Old School Heavy
One man................... on a mission........................... to save the world! .................................................. .................................................. ........................ From the evils of the 50cc pump.............................................
Old 11-22-2013 | 07:11 AM
  #34
snook's Avatar
And dual planes,lol
I have this extra, havent needed it yet, but it has a pink cam in it, why is that????
http://www.summitracing.com/parts/qft-21-103/overview/
I dont have a q series carb, but this was on sale at the local speed shop for 10 bucks so I grabbed it, it should work if I ever need it right???
Old 11-22-2013 | 08:32 AM
  #35
It is a 31 squirter. Thought that was avg size?
Old 11-22-2013 | 02:34 PM
  #36
Pop N Wood's Avatar
Hey, if you guys were really paying attention you noticed I skipped the last couple of intake discussions. From now on any intake/cam question will be given the approved LS1TECH carb forum answer of Edlebrock 2216 and RPM performer. No sense fighting it anymore. Street = dual plane, Strip = single. Figure that way there will just be that many more slow cars out there I can beat.
I was gonna skip this discussion too but contributed for two reasons. First is because I followed the same advice from this site when I first got started. 50 cc pump, hollow screws, brown cams, massive nozzles, basically just dump enough gas on the floor of the intake and let the motor pick up what it needs. Realized this is very easy way to tune a carb to run WTFO.
But after some time running that way I realized it doesn’t do much for normal driving. An accel pump just doesn’t do much when the throttle is just lightly moved. Then there was always a handful of guys on here who didn’t need the bigger pumps. Something didn’t connect.
So no problem. If you want to be one of those guys who tunes a carb only through bolts ons like jets and accel pumps but are afraid to touch an intermediate circuit, then hey, no problem. 2 out of 3 circuits tuned right isn’t bad. Just always stay in the throttle and it’s all good. I mean after all, “that’s what the car wants”.
The other reason I contributed is a personal fault, but the only way to learn is to ask questions. Sometimes if you challenge peoples line of reasoning it forces them or someone else to explain things in a way that finally makes sense. You wouldn’t believe the number of people I irritated about steam vents before I got that one straight in my head. Thank you John McGraw.
Old 11-22-2013 | 02:44 PM
  #37
Old School Heavy
Don't be mad John. Just having some fun. I tease Zone about his fascination with the Edelbrock cams too. All for fun.
Old 11-22-2013 | 04:04 PM
  #38
Pop N Wood's Avatar
No worries. Thought some people might get a laugh.
By the way, if the OP is running a 31 squirter than rant aside I really doubt you need the bigger pump.
Old 11-22-2013 | 04:57 PM
  #39
yeah i'm running 31 squirters on front and rear. i would have to snap the throttle to get it to rev....if i barely cracked the primary it would **** on itself...backfires, and kill the engine if i held it there.
i'm not opposed to looking into your method of tuning a carb and then decide for myself. i'm still stumbling myself through the basics though. everything zane has said to do has worked beautifully so far. i haven't put a wideband or even a vacuum gauge on it yet. hell i don't even know what my timing is set at. it's a used MSD 6012 with the #6 chip in it.
Old 11-22-2013 | 06:35 PM
  #40
ZONES89RS's Avatar
In-Zane Moderator
Well, the way he says you make the carb work without a larger accelerator pump is the absolute correct way.
I will tell you this, if it works, don't fix it. And the 50cc works and has never done anything but solve my stumble. On top of that, I just don't feel like spending time drilling and what not to not need a larger acc pump. If you do it the right way, more power to you, and it is a great option.
And I need to swing by and throw a tune in there for you.
Quick Reply: squirter size
