6010 problems!!!!
1. The wiring is without question correct and all has been replaced as well.
2. Reluctor wheel is present and is 24X not 58X
3. If I understand correctly by the comments the 6010 will not start without a cam sensor the way a GM LS series PCM will. Is this correct?
4. There is no mention of exactly what type of cam sensor configuration is being used on this engine. Is the cam sensor in the back of the block? If so, does the cam have a reluctor ring on it? If it is LS2+ style is the cam sprocket correct and installed properly.
5. Are you using the black 24X crank sensor and not the Grey 58x sensor?
6. Does this engine have an aftermarket stroker crankshaft in it with a larger rear counterweight? According to other things I have read this seems to be a common problem with the 6010 and stroker cranks.
If the MSD 6010 requires a cam signal to fire you need to get an oscilloscope on the cam sensor to see what is going on with it. Better yet if you get a dual channel oscilloscope on both you may find the root of your problem.
someone tell me this though, if GM, and aftermarket controllers, using FI can have no problem, why cant MSD make it fire
Ign is ign, regardless of fuel delivery-a lot of hi comp FI engines, I am sure they all don't spin fast
so whats diff bet. them
Either way the reason for posting in this thread is we had one on the engine dyno and could not make it fire under any circumstances. Even spinning the engine 400+ RPM did not result in a functioning system and even tried two known working boxes and harnesses. Plugged the FAST box in yesterday and it busted right off. Go figure.
