msd 6010 map sensor ???
As its been found out using the pills or not zeroing out and having in the curve "think" it's there; it will add advance in...not what you want.
Since you're going blow through, you'll need it to see the pressure and retard timing.
Mine is from a 2004 Silverado.
I stuck a hose barb in the intake, and used a short (1"?) piece of 3/8" hose to connect it.
If you do run one then with the boost you will want a 2 bar unit. I'm not sure what GM cars run those. Probably get one off a 3.8L supercharged unit. If you run more than 15 PSI boost than you will need a 3 bar unit.
You could play it safe and flat line it at your max timing, but would cost you a lot in low boost areas....should be fine to just get started and see where you're at for idle ?
MAP curve....just flat line at 0.
I would not make any full pulls like this without some type of data recorder and AFR meter running....But just to get started only.
been a while since I used the 6010, but I used a 2 bar map sensor, once it hits around 14.5 your into boost, so like 24 would be 10 lbs of boost
at idle it takes aprx 2" of vac to pull down 1 PSIA, so if you idled at 14" of vac., you would be reading around 7 PSIA, so you can set up your timing based on that
took me a while to wrap my head around it
you can just use the RPM scale, but I liked the map scale once I learned it
