update
Whats your take on the weight being so odd between fr/lr balance? We were thinking a weak spring or somethin causin it to lean?
Kinda bummed it weighs so much but that 8.8 is HEAVY! I would guess close to 75# added vs the stock rear. And the cage maybe added 85#
also, were you sitting in it when you scaled it out?
When I scaled the Camaro, we simulated added a second battery to the car to see what the numbers would be. Adding 45 pounds to the right rear, changed all the numbers for all four corners....actually lightened up the left front...
It leans to the side some so were thinking a bad spring. I have all wiring except lights pulled from the truck. The right side has the fuel lines, main power wires, battery, 1 gal surge tank, bosch 044 pump, and the coolant overflow vs the left. Should be more than enough weight to overcome the extra stuff on the left side.
Anyways im happy with the weekend project. Cant wait for the dyno day and a couple track trips coming up.
Ive got more gas in the truck than I thought. Its a 34 gal cell with about 3/4 tank. That adds up.
I dont see how people can get these trucks and even the newer ones so light. I think they dont have a accurate way to measure and theyre guessing. My truck is about as light as you can go without gutting panels and runnin a fiberglass hood, and still be able to reliably put the power down. I could shed weight with a aluminum ls2 block I guess.
That is why I never went for one myself...
A 10 gallon is all that would fit in my spare tire area. Lol
The mustang on the other hand.... I need a GPS speedo for it. Lol
