msd reading wrong timing
when i was getting it dyno tuned the guy mess with the carb a bit. he said quick fuel had it pretty much dead on and only changed out the primary jets to one step bigger. ran and idled better. and when it came to doing to timing on the msd 6010. he noticed i had a timing curve which was high. something like 36* he lowered it to 31 and ran like doodoo. do he put the motor on #1tdc marked the balancer and checked the timing with a light a noticed it was reading about 4-5degrees too high. which would explain why the higher curve ran better i was short on funds then so i didn't have him go in it further. so my question is could it be a sensor issue? which sensor should i switch out? crank or cam? or could it be that the cam degree is off from when it was installed? any help is greatly appreciated. i want to do some research and gain info and do what i can before i take my truck to a shop and have them dig into it
here is the timing curve
20-32* 0-500rpm
32-24* 500-1250rpm
24-29*1250-1900RPM
29-35* 1900-3000rpm
35* from 3000 to infinity.
thats the timing curve i was given or else it wouldn't want to idle and would bog down at lower rpm.
heres a pic of the truck
Did you do anything to the bottom end?
Heck, that might explain why some cars seem to perform better than others of the exact same model when stock?
Here it is on the dyno.
Many have start issues with their 6010. I don't
read around and with the 6010 box its a common issue. so its distributor time.
Also what valve train/motor combo. Truck valve springs are very weak and will float at high RPM
BTW that truck totally rocks. I would love to have something like that.
