t the best heads i should be running
ok I have a 2001 4.8 with a gm hot cam 219/228 525 lift 112 lsa and a street deamon 625 cfm and 862 heads. this is in a 74 mgb weighs about 2300 with me in it. I have a turbo 350 and a ford 8 inch rear w/ 279 gears. this winter I will be putting a 2800-3000 stall. any ways what heads do you recommend for the best torque/hp. I rebuilt her last winter all new bearings, rings and gaskets, I was wondering also I have the edelbrock/msd ignition box non programmable. I really cant figure out what pill is the best. I have been looking at the 243 heads or 799 just not sure any help will be greatly appreciated thank you
Yes bud. Stall is one of the most important parts of a vehicle. I would definitely address that first before I went with heads. Also, I'd probably try to do a bigger one then what you are looking at.
