Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
msd 6ls or distributor
Old 11-10-2014 | 12:57 AM
Chris05's Avatar
One thing I do like is not messing with a distributor, like I had to on my old sbc. The 6010 is so easy to tune.
Old 11-11-2014 | 11:52 AM
ATwelveSec02Z28's Avatar
When using ignitions like a PowerGrid, with a flying magnet crank trigger... All I had to do all year was turn the distributor a little to re-phase it (making sure the rotor was near the post on the cap when pulling 18-20º of timing for nitrous)
Most of the time, you don't even need to mess with the distributor or crank trigger.
Old 11-11-2014 | 09:46 PM
dogsballs's Avatar
yep, loosening one nut and rotating dizzy not that hard to do.
Old 11-11-2014 | 10:35 PM
ZONES89RS's Avatar
In-Zane Moderator
That's not it, it is stabbing the damn thing, running the firing order, making sure it is not 180 out, all that BS. I plug the ignition up and bam, it fired. Not to mention the dwell time on 8 coils is way better along with all the features if timing retard, 2 step and it is a **** ton cheaper.
Old 11-12-2014 | 12:11 AM
UOP's Avatar
UOP
Not to mention you don't have to deal with weights and springs to get your timing curve exactly right. A few clicks of the mouse and you're done.
Old 11-12-2014 | 12:12 AM
dogsballs's Avatar
hahaa
a good ignition like the 7al3 has all that, combined with hvcII coil will throw a killer spark
Old 11-12-2014 | 04:59 AM
ZONES89RS's Avatar
In-Zane Moderator
Sounds expesive as hell, not to mention the front conversion cover is over 600$?
Old 11-12-2014 | 05:18 AM
VLS1's Avatar
+1
Especially with large duration camshafts.
Old 11-12-2014 | 09:01 AM
dogsballs's Avatar
Lock it out 26degs
I had no problems selling my front cover, inlet manifold, etc off the long motor i got
Old 11-12-2014 | 02:12 PM
ZONES89RS's Avatar
In-Zane Moderator
Originally Posted by dogsballs
Lock it out 26degs
Then you have to use a junky ford distributor setup too? Blasphemy.
Old 11-12-2014 | 02:14 PM
speedtigger's Avatar
Old School Heavy
Some of the Ford guys claim that the LS is just a copy of Ford's small block, so I guess it only makes sense. LOL Yet so many toss their Ford engines in the dumpster for an LS Hmmmm.
Old 11-12-2014 | 03:16 PM
  #32
ZONES89RS's Avatar
In-Zane Moderator
Yea, never seen a ford pushrod 302 or 351 do what the LS does without taking out a mortgage on your home. Lol
Old 11-12-2014 | 03:30 PM
  #33
fast89stang's Avatar
yeah my buddy had one(351) in his car. Ran 6.27. He had aftermarket heads, glide, vac pump, steep gear blah blah blah....I run all my stock junk. lol
Old 11-13-2014 | 04:54 AM
  #34
ZONES89RS's Avatar
In-Zane Moderator
Yup, and it makes the butt hurt strong with the ferd girls. And the ones I know are yelling coyote swap everything now because they think guys like me would care if people threw a ton of money at a ford swap into anything. It will never be on the LS swap level in a million years.
Old 11-13-2014 | 06:08 AM
  #35
VLS1's Avatar
Lock it out 26degs
Yeah and many of us here would most likely have experience with that too, knowing it is still a compromise. Idle and off idle throttle manners are much more tractable with a few degrees less at idle and a nice timing curve up to around 2200-2500rpm.
The distributor setup would have yielded zero performance gains, at least on an engine that runs under 8000rpm anyway.
Old 11-13-2014 | 08:18 AM
  #36
Comical..... Obviously no one has used a modern ignition box like a power grid or even the dinosaur 7531...
I can make a timing curve in either. And it can do ALOT more than a 6010/6012.
Bottom line is a 6010 is quick cheap and easy for guys on a budget looking to get their car running. But if you're a serious racer a 6010's capabilities are insufficient
Old 11-13-2014 | 08:24 AM
  #37
Old School Heavy
Perfect summary in my opinion.
Old 11-13-2014 | 09:16 AM
  #38
streetknight2's Avatar
JCR Wiring in Texas told me they can piggy back a GRID onto a 6010/6012
I may try that route
Old 11-13-2014 | 11:30 AM
  #39
3pedals's Avatar
That would be awesome!
Old 11-13-2014 | 02:19 PM
  #40
ZONES89RS's Avatar
In-Zane Moderator
I agree some what, but I don't use the MSD to get my car running, I get it because it does everything I need.
And I have street cars not "serious" race cars, lol.
Quick Reply: msd 6ls or distributor
