testing ls3 supervic tomorrow
Stock cube Ls2 with 12.7 compression quickfuel 850 2 inch headers Martin Smallwood nitrous cam ported Ls3 heads powerglide ..gonna dyno on motor and the 300 pills swap intakes make any jetting changes it needs and make another pull..hope this thing makes more power..
Did you get all the mounting hardware for the SV?
If you can find some grade 8 nuts for the 2 studs I'd recommend it. I used Grade 8 bolts, but couldn't find the 2 nuts in that grade. I've had mine off twice now and the nuts are rounded off now
Yes..made no difference on motor...Made 506 with both intakes graphs looked similar... on the nitrous it picked up 11 hp..gonna take it to the track and see what it does there
