new best!
#43
im still wanting to take the factory seats out, hope to lose at least 60 to 100 pds,, but will add back some when I put cage in it... but that's like 65 pds tho.. I like to get it under 2400. with out me.. im going to take the hood latch and parts that goes with it off and go with hood pins, plus I took out more wireing. you would not believe what you can remove to lose the weight on the car...
#44
#46
well, i found that the rear lca's are at an approximate 3* upward slope from rear axle to body mount and intend to get that closer to 0* since IC is so far back in my car with the short arm. I believe that with shock tuning and a milder IC i can control the hit well enough to allow the tires to work.
