Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
first time out with the new setup
Old Apr 26, 2015 | 08:57 PM
Footbraker67's Avatar
Default first time out with the new setup
Had a succesful night testing the car. Its got plenty of room for improvement. its a 1967 chevelle with a cam only lq9 with stock 317 heads. 1.55 60ft, 7.17 @95 in the 1/8th. And an 11.37 to the 1/4. I need a different convertor, it hits 6,000 really quick and quits pulling after that. But all in all it was a successful first outting.
Old Apr 26, 2015 | 10:06 PM
Nickelndime's Avatar
Very cool. I just got my Camaro running with the same cam only lq9, I hope to get it to the track this coming weekend. What's the race weight on your Chevelle?
Old Apr 26, 2015 | 10:47 PM
Boostedhatch's Avatar
Nice run and setup. How much you think the vacuum pump is helping? And how hard was it to convert the truck pump over to the electric set up?
Old Apr 27, 2015 | 04:39 AM
Doug G's Avatar
Nice
Great first outing.
Old Apr 27, 2015 | 07:56 AM
Car weighs 2950 without me in it. The water pump wasnt to hard to do, i just had to build a bracket for the motor and install the pulley on the pump.
Old Apr 27, 2015 | 09:40 AM
ZONES89RS's Avatar
In-Zane Moderator
My Camaro was 3150 wo me and 3450 with me. 7.0 at 97 was its best, being a manual trans helped but that tells me you have plenty left in that combo for sure. Looks great man!
Old Apr 27, 2015 | 10:29 AM
windmill's Avatar
How you like the global west front control stuff,, I have it on my 67 chevelle too... tell me more on rear end setup. im doing a notch frame on mine. hoping to get some 28x13.5 drag radials on mine.. what pan did you use and mounts.
Old Apr 27, 2015 | 05:02 PM
The global west stuff is nice but i would buy TRZ if i had to do it all over again. The rear is a stock width 12 bolt with 4:88 gears and a strange spool. I did my own mini tub by cutting the frame rails in half and welding them back together and adding supports. I could fit a 12 inch wheel if i narrowed the rear end but for now its a 29.5 10.5 on a 10 Inch wheel.
Old Apr 27, 2015 | 05:04 PM
I am using a f-body pan. The GM muscle car pan hung down an inch and a half below the crossmember. The mounts are some cheap aluminum adjustable ones I found on amazon.
Old Jun 5, 2015 | 08:29 AM
Steves69ss's Avatar
Very Nice! I'm going to run that same engine head combo carbed in a 69 Camaro and wanted to change the camshaft and maybe valve springs, rockers and pushrods if needed. What cam did you go with? Thanks
Old Jun 5, 2015 | 02:26 PM
LQ4BU's Avatar
Nice car! Great times for first time out.
Your weight and times are very close to mine!
Old Jun 9, 2015 | 10:02 PM
Been back to the track a few times now. New best times are.....1.51 60ft and 7.00@96 mph in the 1/8th mile
Old Jun 9, 2015 | 10:51 PM
