Nitrous/turbo 454 lsx 1400hp
I'm build a 454 lsx turbo motor that will have one large turbo. Off the line, I am going to spray the car with a 175 shot to help spool the turbo faster.
With this in mind, who would recommend a carb setup or an efi and why?
Type of efi or carb?
OK, you will require STRONG coils, the IGN-1A kit will work.
My IGN-8 (two GPIO's) will run the NOS, staged, with your carb.
My ECU-882C-2-H-TTL will work fine if you choose EFI.
Your choice of either BOX will allow simple NOS "non-operation" when you have turbo spool.
The ECU-882 & IGN-8 BOTH have internal MAP sensors, board mounted.
Lance
Lance
I know Jegs has a fuel injected 454 kit that is a complete engine (don't remember if it includes sensors) it even comes with an ecm. Basically just drop it in and plug it in and it's good to go, $13k. It's not a bad price if you just want a well performing daily/weekender/showcar
http://www.jegs.com/i/Chevrolet-Performance/809/19355573K2/10002/-1
