Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
opinions on cam purchase
Old Oct 25, 2016 | 12:36 PM
fast89stang's Avatar
Default opinions on cam purchase
ok. Now that the 6.2 is in the car, and made some VERY good runs with my 6.2 cam, which was designed around my 9.8-1 compression 6.0, would I benefit from having a cam spec'd for my 6.2 with 11.5 comp? Would it be worth anything or just a waste of time and money? At this point I don't expect a 3 tenth gain, cause I know that's getting hard to come by at this ET, but If it can improve a tenth or so, it might be worth doing over the winter. Speedtigger, I know you are a smart cam guy and value your input.....entertain me please.
Old Oct 25, 2016 | 04:24 PM
crossbreed383's Avatar
Mr Curtis did your 1st cam which appears to work very well
He would know more than anyone what would be a step forward or back
Old Nov 1, 2016 | 10:36 AM
speedtigger's Avatar
Old School Heavy
You were 231/243 on 111+3 right?
Old Nov 2, 2016 | 12:26 PM
Man, you got a memory. lol yes it is and the lift is 622-600.
ivo 7.5 btdc closes 43.5 abdc
evo 55.5bbdc closes 7.5.
Old Nov 2, 2016 | 12:41 PM
I have access to this cam, not sure if it would improve or not. Opinions?
Old Nov 2, 2016 | 01:20 PM
Old School Heavy
That is not the direction I would go in. What upper RPM limit are you imposing? You have an 8" 5500 RPM stall right?
Old Nov 2, 2016 | 02:58 PM
236-248-112 l/s in at 109* Imo would be close
Others may say add more exh duration but im not sold it needs it
Shift it a 7400-7500 rpm I would think- with same trap rpm
Old Nov 2, 2016 | 03:32 PM
Old School Heavy
I think that IVC is on the late side for a 11.5:1 naturally aspirated rectangle port 6.2 liter shifting at or before 7500 RPM.
Old Nov 2, 2016 | 03:51 PM
Only 3 degrees IVC longer than his current cam I believe??
whopping 2 degrees more overlap
Old Nov 2, 2016 | 04:14 PM
Old School Heavy
If he has a 5000+ converter and he is looking to shift at 7300-7500 RPM, I would rather see him in something like: 236/248 109+3. With lift at .629"/.604" if he is using stock rockers.
Old Nov 2, 2016 | 04:32 PM
So I am officially conservative in my old age lol
Old Nov 3, 2016 | 12:20 AM
I shift early I guess. I'm shifting at 68-6900. I do turn it up occasionally, but only if I'm behind.AND I do have stock rockers.
Old Nov 3, 2016 | 12:23 AM
yes. 5500 8 inch. Only limits I set is what this thing sets for me. There really are none. I guess i feel ok with 7500. Never shifted there.
Old Nov 3, 2016 | 08:50 AM
Old School Heavy
Then I would grind you a 236/250 109.5+3.5. With lift at .629"/.604". It would be grind# XA236/370-XA250/355-109.5+3.5.
