Hard Start issue !updated!
Ask anything that i may have left out!
Thanks in advance!!
I've already downloaded the software and set up an inatial tune. Based off some of the timing from the EFI tune. Just wanting to make sure the next move is gonna help fix it not wanting to start up.
Is your motor E85? Cause I'm wondering how much the fuel is playing into the hard start issue.
Iron LS408ci
13.3 to 1 compression ratio
Trick flow 235cc heads
Callie's crank and rods
Custom diamond pistons
Total seal rings gapped for nitrous
Custom specd nitrous cam
654/647 lift 251/262 duration @50 111+4 lsa
ARP main and head studs
Edelbrock Vic JR
Quickfuel 750cfm E85 mechanical secondaries
Adding a MAP sensor really helped my LS2 start more easily. Allowed me to pull out static timing and make up for it with vac advance. I run a stock cam and had to set my 500 RPM timing stupid low to get the idle speeds down while keeping 20 thousands of the transfer slot showing. Really helped spin the motor faster during cranking. You probably won't need to worry about that with your big *** cam but try reducing the timing at 500 RPM and add it back in at 1000 RPM
You confused me, you said you have already loaded a new tune? The Edlebrock boxes don't have a serial port, they won't let you hook up a lap top and don't allow custom tunes. If you already have the type of box that allows connecting a laptop than you don't need a 6014 box. With that much motor you absolutely must ditch the pills and tune by laptop.
Carb motors like more full RPM timing than EFI so be a little careful with EFI numbers.
What sort of cranking RPM are you reading on the laptop when trying to start the motor? Maybe you need a gear reduction starter. Big displacement, big compression, big cam = tough to crank.
Also how did you tune the carb, do you have a wideband O2 available? You checked for vac leaks?
Those are good heads. What cc chambers do they have. Because it sounds like you got the same pistons we have. 13.3 Diamonds. We have 65cc chambers and it puts us at 14.2:1 to be exact with those pistons. Your cam specs are very close to what we had. Hopefully you got light weight valves in those heads. If not I would change them. We had Pac double springs good for a .650 lift and they were not strong enough. The valves would start floating around 6500. And make sure you have at least .120 wall push rods too. Hopefully this helps. That bad boy is going to thump hard. Ours is a father and son project as well. You guys are going to have a blast. Best of Luck.
Also, I was under the impression you had an Edy box. Those cannot be programmed. You can only use those pills. Like already stated, if you can program it, you will not need the 6014.
Sorry no i dont not have the 6014. I downloaded the software to check it out and see what it was about. I like it simple and straight forward.
The graph i have to start with ramps from 27* to 32*. EFI wise it made max power at 32* and liked to idle at 27*. And Ii know carb likes more timing so i thought this might be a good starting point.
i do not know on the cranking rpm. im still using the factory starter from my 2000 Trans AM. ha! We've had it smoking a few times trying to start this damn thing. LOL! We have talked about getting a different starter. Just not familiar with them and how much it may actually help.
Ive just done basic tuning so far on the carb. I haven't been able to get much past that. I do have a wide band. Just haven't pulled it out to use it yet. Vacuum leaks i haven't checked for. There's only one vacuum port and its for the map sensor that came with the edy box kit. The big port on the back of the intake is plugged. Car has manual brakes.
well that's sounding great. sounds like the 6014 is bout to be ordered. Dad already said to order it if i think this will fix it. Just tryin to make sure first. ha!
The heads are right out of the box with 70cc chambers. The only change was the springs. i added PRC 675 lift springs. I do have a custom piston though. +10.6 dome.
Doing a lil looking around. And i like what im seeing with the
Powermaster power plus max PN- 9009
I see one rating saying its good to 14-1 and another saying upwards of 16-1 compression. Either way that's more than i have.
I built motor for a good shot of spray. But dads not a fan of that. Do motor will be na for a while. Ha! But this box allows me to add it later now. I think I only have .080 wall rods now. But like I said we're not going for all out power at the moment. So won't be slot of high revving rpm's. Just want to be able to drive this thing a lil bit.
Powermaster power plus max 9009 on jegs for $190
Msd dynaforce gm ls series 5096 $302
Well the first pump i ran was a meiling high pressure/high volume. And something was wrong with it. i had to use my trans pressure gauge to see exactly how much pressure i had it was so much. Just a blip of the throttle and it would have 180psi of oil pressure. Changed the spring and no better. i ended up with a ported LS6. it'll be 40psi at warm idle and close to 100psi WOT.
Melling. But to use a standard volume, high pressure Melling. But that pump you got is very good. Sounds just like our oil pressure.
But was curious as to Walmart plug your running with your motor. At the moment with it being to hard to start I've been having to run a pretty hot plug. Like a TR6. I know I need to atleast be a BR7EF on motor with maybe a small shot of spray and in the 8-9 heat range prolly on anything 200 shot and up. But anything non projected makes it even harder to start.
