Carb with stock ECM from the LS
That has been done, or at least attempted, a couple of times on here. Good work, I salute your inner hillbilly ingenuity. Wouldn't mind hearing details, seems like there were more than a few issue to making it work.
But at the same time seems like the worst of both worlds solution.
For what chassis?
You would be fine with all the sensors retained that inmention. But, we found the TBI throttle position sensor will work with it and you can steal the little arm off the TB from a 88-91 2 barrel throttle body. Keep the coolant temp, oil pressure, all that. Should work pretty awesome.
Originally Posted by AnotherWs6
Nothing about that ^^^^ that is not hillbilly. Nothing.
Seems to be running good man keep up the good work.
The following users liked this post:
cosmo420 (07-07-2020)
