Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Holley sniper efi
Old 07-02-2019 | 06:31 PM
LLLosingit's Avatar
Originally Posted by G Atsma
I think Project GatTagO means the Terminator X which is about $1000. But I could be wrong...
You're not wrong lol, Calling someone ignorant and then posting a different system is just....well....Ignorant.
Old 07-02-2019 | 06:35 PM
I think 0352Marine owes SOMEBODY an apology.....
Old 07-02-2019 | 07:44 PM
Project GatTagO's Avatar
I wrote exactly what I meant. No apologies necessary. The Terminator X starts at $1k.
Andrew
Old 07-03-2019 | 08:53 AM
panda240ss's Avatar
yeah terminator x starts at 1k. and i mean you can use just about any intake for that system....
Old 07-03-2019 | 10:19 AM
LilJayV10's Avatar
IMO it depends on your goals. If you are wanting to make a lot of power using a traditional intake would probably be better instead of spending a crap load on a FAST/MSD intake.
If you are wanting to keep a "stock" look the carb intake is going to be the best bet. Some people just don't like the way plastic intakes look.
With a wet intake/carb you have the benefit of cooler IAT's, which may or may not be important to you.
To use the Terminator X, you would have to use a carb style intake w/ MPFI and then buy a throttle body. (I haven't installed a Terminator X yet so I'm not sure you can actually configure it that way)
If you want a carb style intake I think the Sniper and MSD timing control would be a cheaper than the Terminator T/B setup.
Again these are just my opinions and several things need to be taken into consideration.
The following 2 users liked this post by LilJayV10:
0352Marine (07-03-2019), Packmanrod (01-07-2020)
Old 07-03-2019 | 04:07 PM
0352Marine's Avatar
I’m sorry if I offended anybody on this site and I now realize you are referring to the terminator x. I wasn’t trying to offend anyone buy using the word ignorant but just simply stated your not familiar in my opinion and my previous experience in this subject if you have experienced this first hand like I have. The terminator x just reinforces my point even more so. With the terminator x purchase for $1,000 your just purchasing a ECM and harness. No type of induction hardware I.E. intake, throttle body or for that matter injectors, MAF, MAP, throttle module and throttle sensor if running drive by wire just to name a few required parts to make it work. This is where it gets expensive. The Sniper master kit comes with fuel pump, throttle body, ECM and harness plus more. The terminator x really makes no sense in purchasing because on a vehicle that already has port injection why would you wanna purchase this when you can pay a tuner approximately $350 with an HP system and get the same results? I understand that some want the modern engine look. But for my application a modern looking engine in my opinion would devalue my truck. I’ve been building LS engines for the last 15 years and I’ve used every type of induction there is for each of my customers, from twin turbo, supercharged and in my own personal engine high compression. After doing all the research on pricing, looks and power this option (Holley Sniper) was the best choice hands down. I’m not sure what your experience is with LS engines but in my previous experience I built 2 6.0L LS LQ9 engines nearly identical except one was for port injection and tuned using the HP system and the other using the sniper with a MSD 6014 box and the sniper made 32 more horsepower. The difference in the installation process was extremely easy for the Sniper in comparison to the multi-port injection. The one engine with port injection was for a customer of mine and the sniper is mine. I’m simply trying to educate people that are looking for a LS engine for their classic car and still have the classic look but have the power and reliability of a modern LS engine. The Sniper isn’t the only way to go but if your on a budget but still want all these amenities, for the price and horsepower I couldn’t find anything else that could compare. Even the more expensive induction systems were nearly equal or less power and less simplicity installation.
Old 07-03-2019 | 05:57 PM
LLLosingit's Avatar
The sniper is just throttle body injection and to use it on an LS you still have to buy an intake and the MSD box and I understand wanting to keep the stock look, It does a good job for what it is.
As far as saying why us the Terminator X system when you could just pay a tuner $350... You still either have to buy a $600 harness or make your own, With the terminator X you also get a 3.5" lcd that you won't get if you use a stock computer. That and you'd have to take it back to the tuner anytime you wanted to make changes. As far as buying everything else needed like intake/injectors/sensors.....90% of the time they come with the engine.
Nobody here wants to get into a pissing match and trust me there are quite a few of us on here that have plenty of experience with the different systems and other than wanting a retro look there is no reason to use the Sniper over the Terminator X or the stock computer. As far as building two nearly identical engines and the one with the sniper making more power, That may be true but "nearly" identical isn't getting you scientific results by a long shot lol. Hell you can build two identical engine from top to bottom and they won't make the same power. Even slight changes in weather conditions can knock 10-15 horsepower off using the same exact engine on the same dyno. In you case with wanting to keep the look of a carb the sniper is the only way to go unless you want to pony up and get the Terminator you linked above.
Old 07-07-2019 | 06:49 PM
5.7stroker's Avatar
427 LSX TT with the goal of making 1300 hp on 20 lbs of boost at 11.1 compression on E85 flex fuel and a holley dominator to control it all.
245 heads port matched to the ported $600 sniper intake. Car doesn't need to make any more HP than that because the ET would be over 8.5 sec and it doesn't have a 25 point cage. Just a take out when it's nice outside heavy *** street car with a 10 point that can be driven to the track, run mid 8's on occasion and driven back home while blasting the AC.
On this theoretical setup, tell me why on a 4th gen camaro I should go for one of those intakes with longer runners that requires you to cut the cowl or get a aftermarket hood or both? I see all these big *** intakes with cut cowls and aftermarket hoods and I'm wondering what would be the benefit of something like that based on the situation above. Does it do anything for the longevity of the motor?
Old 07-07-2019 | 07:15 PM
LLLosingit's Avatar
Just curious, What does an intake question have to do with the Holley Sniper throttle body topic?
Old 07-07-2019 | 07:21 PM
5.7stroker's Avatar
Just curious, What does an intake question have to do with the Holley Sniper topic?
One holley sniper is as good as another
https://www.holley.com/products/inta...parts/822102-1
jk saw the topic after a search and didn't realize this topic has nothing to do with the intake.
Old 07-07-2019 | 08:25 PM
LLLosingit's Avatar
The Holley Hi-ram/ MSD Atomic/ Fast/ Edelbrock are all good choices but hood/cowl clearance seems to be an issue with the F-body.
Old 12-27-2021 | 04:46 PM
  #32
Formula Freak 76's Avatar
Default Transmission control
Originally Posted by forcd ind
Just let the MSD control the ign., let the Sniper control the fuel, works great.
What about controlling the 4l60e transmission?
​​​stock harness from donor vehicle?
Old 12-27-2021 | 05:01 PM
  #33
pdxmotorhead's Avatar
You would need a TCM, there are several aftermarket ones they have gotten fairly economical ,,
but I think based on the original question he would have already had to handle that.
Biggest reason I can see to replace a carb with a sniper is the packaging.. it fits in older cars that had carbs..
The one using regular injectors instead of the old TBI egg injectors do some impressive stuff.
I"ve seen refurbished ones not eh Holley page for < 1000.
TBI gives up nothing significant to MPI, if your looking at top end power. even boosted,
heck way way back we were slapping a turbo of a diesel truck on big block chevy
engines with 4 barrel TBI and making stupid power for the time.. (Mud trucks... LOL)
Old 12-27-2021 | 05:12 PM
  #34
I wouldn't do a TBI system on a LS, but if you wanted to, you could do a TerminatorX Max Stealth, that will have transmission control for a 4L60e.
Andrew
Old 01-19-2022 | 08:57 PM
  #35
ZONES89RS's Avatar
In-Zane Moderator
So, after trying to get a Holley sniper and MSD 6014 to work together……
you use the purple wire that is wrapped with the green wire for the tach signal.
this had me chasing my tail why the yellow wire would not work.
4 sources said to use yellow and they were wrong
just a heads up for folks searching this ****
The following users liked this post:
JohnnyRacer (02-14-2022)
Old 02-14-2022 | 04:08 PM
  #36
JohnnyRacer's Avatar
Outfrigginstanding! I was literally just searching for this answer right here. So the Crank Signal Sensor Positive (+) violet wire from the Sniper system goes to the to the tach output grey wire on the MSD6014 box. Then the rest of the the MSD6014 gets wired as per the instruction manual correct?
Now...What do you plug in to the Engine Coolant Temp sensor into? The MSD box or the Sniper? I am assuming the digital dash I am running will pick up the ECT reading from the CAN bus on the Sniper system (where the 3.5" screen would have been plugged into) if I am supposed to plug the Sniper lead into the ECT sensor but not sure that would work if the MSD lead gets plugged into the ECT sensor.
Old 10-26-2022 | 08:47 PM
  #37
63Impala5.3's Avatar
Default Holley sniper
Do you have a wire diagram or know where I can find one. I have a 5.3 with LS msd box and super sniper but I can’t get the wiring right
Originally Posted by 70ssclone
I did ! If you need any help pm me . I have a 6.0 with 243 heads and a 230/236-596-586-112 cam . It works really good however at the current time I'm about To go from a dual plain to a single plain intake because of a few issues caused by the dual plain . Car idles better and has more stable afr and the harness from Holley is plug and play and very neat. Your 6014 will work just fine .
Old 07-17-2023 | 03:39 AM
  #38
BigEd_72455's Avatar
Thumbs up
I know this is reviving the thread from last year before Christmas, but the info I am providing is important for anyone searching.
Run one for the Sniper (drivers side front of the head) and the other to the 6014 (passenger rear). They can be found on eBay for under $7 each plus tax.
https://www.ebay.com/itm/403100774009
Pretty sure same one works for both setups since both ignition and MSD box are Holley products.
As for the wiring, You have to run the Holley configuration wizard and make sure to tell it you are using CD Ignition.
You can then connect the tach wire (yellow) from the 60 series to the purple wire in the MSD twisted pair wires of
green and purple. Either cut and splice to make this connection, or buy the extension harness and make your own. PN 8860 MSD
To test it before doing cutting and splicing, just bare off a little of the yellow wire from the MSD box, and insert it into the purple wire of the Sniper.
Crank the engine over watching for RPM signal on the Terminator display.
If it doesn't show, you need to make sure to run the Configuration Wizard again before trying again.
This is also the same wiring setup you would do for the Daytona Smart Spark in case anyone is wondering.
But that unit is EXTREMELY picky about coils apparently.
I bought a 6010 used to not have to chase down what is wrong with the Daytona setup,
even after trying to get it going for over a month.
https://www.ebay.com/itm/154792596620
Quick Reply: Holley sniper efi
