This car is driving me crazy.
Here is what I have, ls2 out of a 2006 in my 78 trans am with t56. I am running a qft hr-780-vs carb, with holley sniper gas tank with fuel pump in tank. I have a automotive dual stage fuel pump regulator knocking the pressure first done to 12 psi and then down to 6.5 psi for the carb. My ignition is msd 6014 box. Timing starting at 15 and going to 28 all in by 1500 rpm.
here is my problem. The car will not run right. I have the idle circuit good with afr in the 13's. But anything after 1/3 throttle under load the car breaks up, bogs, backfires and sometimes stalls. Seems like it is going lean. Not sure if it's carb tuning or fuel starvation.
thanks for any help!!
It could also be ignition related, As cylinder pressure increases so does spark resistance. I would make sure everything is grounded good, Double check plug gap. My Son-inlaw had a terrible miss under load and it turned out to be weak plug wires arcing to the headers under load.
