Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Ls7 or ls9 cam?
Old 02-08-2018 | 07:38 PM
dawgs74's Avatar
Lightbulb Ls7 or ls9 cam?
im putting together a 370罵q9, I have ls3 style heads with 64cc chambers.....with that said I think the compression is around 11.0:1/11.3:1 I知 thinking of going carb on this one I知 just curious if anyone has experience with this setup and if a ls9 or ls7 cam will work carbed , I知 assuming it would have to be single plane but not sure anyone got any suggestions........I have everything but the cam and valvetrain ready to go,just gotta go with a nice cam not trying to make a max effort.........just good fun!
Old 02-08-2018 | 08:36 PM
There is so little difference between the two cams you might as well get what you can get cheapest- the LS9, which can be had for around $100
Old 02-08-2018 | 08:56 PM
dawgs74's Avatar
do you think that cam will be better with a dual plane or single plane intake?
Old 02-08-2018 | 09:09 PM
Not sure I am qualified to answer that. Just figure it has a HUGE split, like it's 211/230 on the duration, plus a HUGE LSA, 122.5 deg. It WILL NOT LOPE. Your manifold gurus will be able to give you a good answer on that.
Old 02-14-2018 | 10:38 AM
pantera_efi's Avatar
Default Manifold Firing Order
Hi 74, the LS Firing Order was created, changed from 18436572, to work better when a Single Plane intake was fitted. (18726543)
Your Hendrick head works well with WIDE C/L camshafts.
Your C.R. of 11.3 works well with WIDE C/L camshafts.
My choice would be the LS-7 "late" camshaft.
I can provide the GMPP (Wegner + PML) intake AND a Holley Three BBL carb ?
Lance
Old 02-15-2018 | 09:28 AM
speedtigger's Avatar
Old School Heavy
Both of those camsahfts have a very late intake valve close event. So, in naturally aspirated 5.7-6.2 liter engines, they are going to have very poor torque and what to see a lot of RPM to perform well. Because of that, the dual plane manifold will perform much better below 7000 RPM.
One thing you can do to make that camshaft perform notably better would be to advance it 4 degrees.
Old 02-16-2018 | 07:35 PM
dawgs74's Avatar
I read somewhere that smaller ls1 cams work great on ls3 heads......bigger is not always better, if that's the case that would be awsome cause I can still run original cam sensor in the rear....is this true? 214/230 .601"/.578" on 117 lsa comp cam anybody run this in a lq9 on rectangle port heads? Will it work with 11.2:1 compression
Old 02-19-2018 | 05:01 PM
Old School Heavy
If you want a real cam recommendation, list everything about your build.
Vehicle weight
Engine size and type
Bore & Stroke
Compression ratio
Cylinder head model
Valve sizes and flow numbers if available
Intake manifold model
Exhaust system details - header size, full exhaust, race exhaust etc
Hydraulic or solid roller desired?
What rocker arm ratio?
What model lifter?
Do you already have valve springs? If so, what part number or specs?
Transmission
If auto, what RPM stall torque converter
Rear gear
tire height
How do you use the vehicle? Daily, weekend toy, street/strip, roll race, 1/2 mile, road course etc
What idle and drivability characteristics do you want?
Old 02-19-2018 | 09:52 PM
dawgs74's Avatar
Vehicle weight
Bore & Stroke
Compression ratio
Cylinder head model
What model lifter?
Transmission
Rear gear
tire height
Yea I should have took alot of these questions in mind before coming to a cam conclusion. ...with that being said I can maybe honestly answer half of them. ....I don't have a planned vehicle for it it was mainly a backup motor for when the 5.3 goes in my 74 nova th350 3000rpm stall. Freeway gear at the moment. ...but these 5.3s last a while and I'm happy with the 400hp from it.....so I might consider swapping into a box c-10 or suburban k5. Possibly older gen c 10 like 67/72. I miss my 72 long bed c10. Had kids. Wife wanted more doors and cleaner emissions so had to get a duramax lol but I want a c 10 to restore with my son cause I don't wanna give him the nova he is 10 now. So Yea it would have to be reliable and daily driven....
Old 02-20-2018 | 10:13 AM
Old School Heavy
Back in the day, I did not care for the 67-72 trucks, now I am sweet on them. Maybe my tastes are "maturing". LOL
Old 02-26-2018 | 04:58 PM
Speedtigger- Not to hijack this thread, but you mentioned advancing the LS9/LS7 cam 4 degrees to improve performance. With that done, how much power improvement would you see this cam giving an otherwise stock LS3? I know, there are FAR better cams... This is hypothetical.
The following users liked this post:
Blk_Ws6 (09-01-2023)
Old 02-26-2018 | 06:15 PM
dawgs74's Avatar
I was kinda thinking the same thing. .....also I was told that ptv issues arrive when you mess with the degrees. .....I'm gonna go with a 224/.560 on a 112 with single plane efi manifold with throttle body elbow. ......370" 11.2:1 compression rectangle port heads
Old 02-26-2018 | 07:32 PM
jarheadl34's Avatar
I am also interested in Speedtigger's comment on the 4 degree cam change. Since I have a stock LS3 with GM single plane intake and a LS7 cam. I am buying a new timing set I guess using one that I can advance or retard the cam would make sense. Do you know anyone that has run their cam advanced? Did it make more power?
Old 02-26-2018 | 07:47 PM
What got my attention was that advancing it 4 degrees would make it NOTABLY (my caps) better. I guess we're all wondering, HOW notably? I doubt it will be earth-shaking, but when you can get the LS9 for about $150 new, bang-for-the-buck goes up NOTABLY too! lol
Old 02-27-2018 | 08:47 PM
Does anyone have dyno numbers on an otherwise stock LS3 with a 4-degree-advanced LS9 cam? I am VERY curious.
Unless Speedtigger comes along and can give a highly-educated guess on this.... if so, thanks in advance!
Old 02-28-2018 | 01:01 AM
dawgs74's Avatar
do you already have ls3 cam? Is a ls9 cam that much cheaper than a stock ls3 cam?in one of my books Richard holdner pulled 497hp out of stock ls3 with the stock 400hp spec.cam....all just by fine tuning. ....so yeah is a ls9 cam really gonna do much better for d/d. $4$
Old 02-28-2018 | 01:02 AM
dawgs74's Avatar
opps meant to say 430hp
Old 02-28-2018 | 10:07 AM
Old School Heavy
It would be a guess for sure. I would guess about 10 HP advantage for the LS9 cam.
Old 02-28-2018 | 10:24 AM
Whoa. Not much! Even WITH the 4 degree advance? Gotta be next to nothing without it.....
Old 02-28-2018 | 10:45 AM
jarheadl34's Avatar
I have seen several dyno posts on various Corvette sites where LS3s were dynoed with stock cam and then the LS7 cam. All of them picked up more than 20HP increase rear wheel HP.
Blk_Ws6 (04-11-2020)
Quick Reply: Ls7 or ls9 cam?
