Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
MSD 6014 map sensor
Old Jun 20, 2019 | 03:43 PM
03weim's Avatar
Default MSD 6014 map sensor
How are people attaching a map sensor to the msd 6014 box? Reading the directions online I can’t find anything explaining how to do it. Pictures would be great too
thanks John
Old Jun 22, 2019 | 06:32 PM
Mark Anderson's Avatar
There is a silver fitting on the ignition box. 1/4 inch nylon air brake tube will push into the fitting. Connect the other end of the tubing to the intake. You can b the tube and a push lock fitting for the manifold end from Napa. The tubing comes in several colors.
Old Jun 22, 2019 | 08:16 PM
03weim's Avatar
Thanks Mark
Old Jun 26, 2019 | 08:58 AM
Ls7colorado's Avatar
what is the advantage of this?
Old Jun 26, 2019 | 09:15 AM
03weim's Avatar
The advantage is you don’t need an external map sensor and it acts like a vacuum advance on an old distributor
