Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Lean at wot
Old Apr 21, 2020 | 06:49 AM
augielsx's Avatar
Default Lean at wot
Alright guys I’m still fighting this lean issue With my 5.3 but it’s only happening when I’m in 2nd or in 3rd and I stab the throttle and I see on my afr gauge that it’s goes lean. When I go wot in 1st either it’s a roll or a dig the cars fine going through all the gears but when I try to roll in a higher gear it goes lean anyone have any advice? Thought it was fuel pump so replaced it and nothing accel pump is working good just not sure right now
Old Apr 21, 2020 | 01:41 PM
Frank400's Avatar
what carburetor do you have ?
Old Apr 21, 2020 | 03:28 PM
augielsx's Avatar
it’s a 750 quick fuel vacuum secondaries
Old Apr 21, 2020 | 03:48 PM
AwesomeAuto's Avatar
Are your secondaries opening all of the way?
Old Apr 21, 2020 | 04:04 PM
augielsx's Avatar
im guessing they are I haven't checkek, even then I thought they were opening to fast where there wasn’t enough fuel for how fast the air was going through so I slowed them down and it is still doing the same thing. If they weren’t opening all the way wouldn’t that cause it to go rich?
Old Apr 21, 2020 | 04:18 PM
Doug G's Avatar
What size jets ?
Also, when you go WOT there will be a high draw of air and it takes the fuel a second to catch up. So, if it's only a spike, that's normal, if it goes lean and doesn't recover, it could be jets or high speed air bleeds ? (to start)
Old Apr 21, 2020 | 04:48 PM
augielsx's Avatar
Originally Posted by Doug G
What size jets ?
primary jets are 72 and secondaries are 83 when I hit wot in first it will hit 12.9 at wot so I don’t think it could be Jets it has to do with something affecting the tip in
Old Apr 21, 2020 | 06:18 PM
Doug G's Avatar
RPM Vs. airflow...
If you look close, this is a WOT run with a full manual TH350 and no lift shifts. You will see the lean spike on the shifts, along with a huge spike at the end of the run when I let off the gas. The AFR will change with the load on the motor even in a steady rpm state.
And just how lean are you seeing.
[img]
Old Apr 21, 2020 | 07:32 PM
augielsx's Avatar
RPM Vs. airflow...
Sometimes it will hit 16 there’s times where I see 19 And I honestly haven’t rode it out to see if it will get richer because it bogs down if it wouldn't bog and and I saw a quick spike then I wouldn’t mind it but the fact that it’s messing with performance that’s why I’m concerned and like I said only happening from a roll in 2nd and third, first gear is fine
Old Apr 22, 2020 | 07:40 PM
Doug G's Avatar
What's your timing look like ?
What's the fuel pressure at ?
What's the fuel level in the bowls ?
