Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
L92/LS3 Vic Jr. Height
Old 06-08-2021 | 12:00 PM
SCJW's Avatar
Default L92/LS3 Vic Jr. Height
So, I have a carb 408 with ls3 heads and a super Vic intake in a 94 Camaro. The issue is that the back of the carb is dangerously close to the windshield. I’m wondering if I switch to a Vic jr will it lower it enough to clear? The super Vic measures 7.25” from the valley cover. Does anyone have this measurement on the Vic jr?
Old 06-08-2021 | 01:57 PM
SLOW SEDAN's Avatar
Dremel diamond bit cuts glass, just go slow and notch it out a bit.
Old 06-08-2021 | 02:12 PM
SCJW's Avatar
I’ve thought about doing that, I’m just afraid of cracking it.
Old 06-08-2021 | 02:14 PM
SLOW SEDAN's Avatar
Could always replace it with an opticarmor unit.
Old 06-08-2021 | 03:39 PM
SCJW's Avatar
Good point! So, would you use a diamond disc on a dremel and slowly score the glass evenly?
Any idea how much clearance I need? I’m using stock ls1 motor mounts with poly bushings. Not sure how much the engine will twist/move under load.
Old 06-08-2021 | 05:10 PM
SLOW SEDAN's Avatar
Ya you dont want to try to cut through it in one pass. Depends how stiff the poly is, mine have a bit of poly and it doesnt move very much. Hard to tell from pic, are you concerned about the engine rocking side to side or leaning backwards?
Old 06-08-2021 | 05:19 PM
SCJW's Avatar
It would take a good bit of twisting motion side to side to make it hit, but if it rocks back any at all it’s going to hit. If I had 1/4” cut from the glass I don’t think it could hit. It’s 1/8” or less from it as it sits.
It was actually hitting it before I filed down the screw.
Old 06-21-2021 | 10:32 AM
SCJW's Avatar
I ended up switching to a shorter GMPP intake and have plenty of clearance now.
Old 06-21-2021 | 10:35 AM
How much shorter are the intake passages? That will affect the torque curve. Shorter moves it higher.
Old 06-21-2021 | 11:58 AM
SCJW's Avatar
They’re quite a bit shorter. It looks like this intake wants 7k+ rpms, but I’m setup for 7,500+ rpms. I’m hoping it’ll be ok for my setup. If not, I’ll try to get my hands on a Vic Jr. once they’re available again.
Old 07-19-2021 | 11:05 PM
2Lane Racer's Avatar
Have you made any comparable runs with both intakes?
Old 07-20-2021 | 08:53 AM
SCJW's Avatar
I haven’t done any comparisons. I was afraid to run it with the super victor since the rear float adjuster was so close to the windshield.
Old 07-22-2021 | 11:13 AM
I think i saw that in another post. Thanks for the repsonse. Good luck!
Old 07-22-2021 | 02:26 PM
biketopia's Avatar
Edelbrock is really good about providing specs on their intakes. Look up the part # on summit or the edelbrock site and it should give a chart with overall height, looks like a super vic part# 2826 is 7.670inch tall and a JR part # 28456 is 7.4" tall. I had similar problems with my GenI SBC carb swap in my 95, I was running a GMPP high ram and it cleared, but it was super tight getting an air cleaner on it for street duty, swapped to a vic JR for SBC and gained me like another inch+. Good point slow sedan on the dremel or swapping to an optic armor. I thought about going OA, but some of the street style races I was planning to run with the car say must have a glass windshield, something to consider OP if you're building the car for a specific use.
Old 07-22-2021 | 03:38 PM
SCJW's Avatar
I’m not sure where Edelbrock gets their specs, but they aren’t accurate. My super vic was actually 7.25” high. The victor jr is a little over 6” if I remember correctly. This is measured from the top of the valley cover.
Quick Reply: L92/LS3 Vic Jr. Height
