5.3 carb fuel setup HELP
Hello all, i have a 1985 K10 4x4 that i am swapping with a 5.3ls, it has a small cam shaft and a 750 carb. I am looking for some help with the fuel system. What have you guys used? anything helps...
The following users liked this post:
Dbunke (11-16-2023)
That 750 is WAY too big for a 5.3. A 600 would be much better
Doug G (11-16-2023)
Well, I have a 68 Camaro with a L33 with a Summit cam (218/227 duration) that makes about 429 hp according to a test performed by Richard Holdener. I run a performer RPM dual plane intake and a Quadrajet, along with a Richmond 4+1 five speed. I am using this very pump inside a Tanks Inc. fuel tank. My regulator is in the very back near the tank, so my return line is about 18 inches long.
You have a few options with electric pumps...Holley 6-7psi max/Edelbrock 5-5.5psi max, so you'll need a regulator...deadhead it up under hood OR return style back near tank or a return line all the way back to tank if you keep under hood.
Elec. FP pushes fuel, so that needs to stay back in/near tank
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
