View Poll Results: Leave it on the ground, or put it in the air?
Lift it!
17
45.95%
keep it on the ground
13
35.14%
F it! Its goin to the shop!
7
18.92%
Voters: 37. You may not vote on this poll
Fourth gen engine removal and installation
Allright, this is for all the do it your selfers either fortunate enough to have a lift in their RV port or garage, or ballin on a budget like me, doin it the hard way. Do you pull / install the motor on the ground, or lift it.
i used an engine hoist and two jack stands.i unbolted the whole engine craddle and front suspension like 9 -12 bolts.i let the whole assembley sit on the engine hoist legs ands used the hoist to pick up the car set the car on the jack stands and wheel out the engine.
my buddy and i did mine and his out of his garage with no lift. pulled the engine from the bottem. had a wooden dolley to move the k member,engine and tranny around once the car was lifted off. just used an engine hoist and had a strap hooked to the radiator support to lift the car from the k member.
i always drop them out the bottom.
I can usually drop the whole k member in an hour. My record is 45 minutes, but that time I pulled it with the driveshaft and y pipe attached, just pulled the y and driveshaft out of the back of the tranny. Y pipe came out easy (hooker). I would not reccommend doing that, I was thrashing to get it out to meet a deadline.
I wouldnt screw with yanking it out the top.
my buddy and I pulled his motor through the top, super easy. Cant imagine it being any easier any other way unless you happen to have a lift, but even then it couldnt be that much easier.
I got lucky, a friend of the family had a lift. I can't imagine doing it out the top, as you have to remove more stuff from the car.
There is a tool called the happy hooker (not kidding), that goes where the intake sits, so that you can pull it out the top easier, but you have to remove the headers and radiator.
out the bottom is the easiest
