RPO codes with VIN?
LS1Tech Administrator
Received 1,784 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Compnine.com should be able to supply that info. If not, you can get it from any GM dealer.
If your looking at a Z4C camaro here's your RPO's...I had to change the Y to a 2
for Vehicle Information
VIN: 2G1FP22G922116173 Model: 1FP87-2002 CHEVROLET CAMARO Z-28
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Vehicle Build
Model: 1FP87-2002 CHEVROLET CAMARO Z-28 Order Number: DPBCGW
Gross Vehicle Weight: 1,930 Build Date: 09/12/2001
Build Plant: 2
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
193 - INT EBONY 19I - EBONY INTERIOR TRIM
1SD - OPTION PACKAGE 04 1SZ - PREFERRED EQUIPMENT SAVINGS
6BS - FRONT SPRING 7BS - FRONT SPRING
81Q - BRIGHT RED BODY SIDE MOLDING 81U - BRIGHT RALLY RED
8TJ - REAR SPRING 9TJ - REAR SPRING
A31 - POWER WINDOWS W/ DRIVER'S SIDE EXPRESS DOWN A90 - POWER HATCH RELEASE
AG1 - SIX-WAY POWER DRIVER SEAT AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS
AR9 - CLOTH BUCKET SEATS AU0 - KEYLESS REMOTE ENTRY W/ ILLUMINATED INTERIOR FEATURE W/THEFT DETERRENT ALARM SYS
AU3 - POWER DOOR LOCK SYSTEM WITH DELAYED ACCESSORY BUSS B84 - BODY SIDE MOLDINGS
C49 - ELECTRIC REAR WINDOW DEFOGGER C60 - AIR CONDITIONING
CAE - UPFITTER CONVERSION - Z28 CC1 - REMOVABLE ROOF PANELS W/LOCKS
DE4 - REMOVABLE ROOF PANEL SUNSHADES DG7 - ELEC TWIN REMOTE SPORT MIRRORS
DL5 - ROADSIDE SERVICE INFORMATION DECAL FE4 - RIDE & HANDLING SUSPENSION SYSTEM
FE9 - 50-STATE LOW EMISSION VEHICLE G80 - LIMITED SLIP DIFFERENTIAL
GU5 - PERFORMANCE AXLE IP3 - INTERIOR TRIM DESIGN
J65 - POWER DISC FRONT & REAR BRAKES K34 - CRUISE CONTROL-ELECTRONIC
K43 - GENERATOR 102 AMP LS1 - ENG 5.7 LITER SFI V8 ENGINE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE MX0 - 4-SPEED AUTOMATIC TRANSMISSION
NF7 - FEDERAL EMISSION SYSTEM NLEV NP5 - LEATHER WRAPPED STEERING WHEEL
PBT - ID TEMPORARY HOOD, PROC OPTION QFK - P275/40 ZR-17 S/B RADIAL B/W
QG4 - WHEEL 17 X 9, ALUMINUM, MACHINE FACED SLM - STOCK ORDERS
STE - ST THERESE, GM OF CANADA PLANT CODE T82 - TWILIGHT SENTINEL HEADLAMPS
T96 - FOG LAMPS TS9 - HIGH LEVEL STOP LAMP - DELETE
U73 - FIXED MAST ANTENNA UA6 - THEFT DETERRENT ALARM SYSTEM
UB3 - GAGE PACKAGE WITH TACHOMETER UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS
UN0 - AM/FM STEREO RADIO WITH SEEK-SCAN,DIGITAL CLOCK, AUTO- TONE CONTROL, CD PLAYER, THEFTLOCK, AND SPEED COMPENSATED VOLUME (BASE RADIO) UZ7 - MONSOON PREMIUM SOUND SYSTEM WITH 8 SPEAKERS AND AUXILIARY AMPLIFIER (BASE SYSTEM Z28 & UPLEVEL ON BASE COUPE)
V12 - POWER STEERING COOLING SYSTEM V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
VE2 - PROTECTOR SOURCE APPLICATION VM3 - CONSUMER INFORMATION LABEL
WU8 - "SS" PERFORMANCE/APPEARANCE PKG INCLUDES: *325 HORSEPOWER *FORCED AIR INDUCTION HOOD *17" ALUMINUM WHEELS *SS SPECIFIC REAR SPOILER *HI PERF. RIDE & HANDLING SUSP. *LOW RESTRICTION DUAL OUTLET EXHAUST SYSTEM *SS BADGING Y2Y - SALES PACKAGE CAMARO SS DUAL
Z28 - CAMARO Z28 Z4C - ******************************* *35TH ANNIVERSARY SPL EDITION * *******************************
Vehicle Information
Vehicle Build
Build Plant: 2
Option Codes
Vehicle Build
Build Plant: 2
Option Codes
Vehicle Information
Vehicle Build
Build Plant: 2
Option Codes
