98 ls1 t56 swap
98 ls1 t56 swap
So I did the t56 swap from a auto. Everything works but the problem is that when I press clutch down an turn key I get nothin! I did what the swap calls for that orange black wire together for hatch then the green an brown for reverse lights but I gt a m6 harness so wasn't needed an I got the clutch pedal both pigtails hooked the y splitter one on brake an clutch then the nutral safty switch to the green an purple an I get nothing? If I touch the green wire from harness to hot wire it fires up
