BlackandGold's project RECALLD Bought not Built
#69
It's a totally different car, I'm hoping for a test and tune down in Lincoln here soon, but as of now I've got it dialed in to feel pretty good on the street. I ended up having to play with the watts a little more than I expected, but much much much better.
As far as comparison, my first camaro a '94 v6 was on KYB adjustables and an eibach pro kit, this is much much much better than that. After that car I had a '00 v6 firebird on bilsteins and I think whatever spring rate BMR was running at the time, it's also much much much better than that car.
All in all if you need new shocks and springs anyways it's an amazing option, rear clearances are a little tight, but the install is straightforward and the combo just feels awesome around corners.
I should have everything up in the air this weekend to do a quick check of all my fasteners, I'm OCD like that, so I'll try to snap some pictures of everything installed.
#70
^im currently running ridetech lvl 2's but the ecm started throwing fits before I got to run the car and dial it in. they use hypercoils springs as well, but not as high a weight. I was just curious as I think you are one of the first to run it so far. I had eibachs when the car was a v6 and then qa1's when I did the v8 swap. I loved the eibachs, but the qa1's were just not suited for a street car.
#71
Before these were released I was torn between the ridetech lvl 2s and koni 4/4s with strano springs. But I was a little put off by the softer rates on the ridetechs. If you're more interested in turning I think the stiffer springs are the way to go.
#72
I had that same hang up course it wasn't a blind purchase. I spoke with Josh several times as I have an iron block with my swap. Different spring rates are available if you want them, but with the shock they are using for theirs the heavier springs aren't as nessesary .for a full out competition setup sure but I think that 600lbs spring setup is a necessity for oil filled shocks as opposed to gas charged shocks. Sam putting his name on it is a big deal though and that shock is based around his input. I'm curious to see how customers take to it.
#73
#76
Thanks for the insight. I'll probably do the rear tomorrow.
I got my front apart. I have decided to blast and powder coat my upper control arms and mounting brackets. Some rust, old ball joint, and energy suspension bushings laying in a box, makes now the the time.
I'm wondering on the shock adapters. The directions seem odd to me and the email to UMI didn't get a reply. Also, tried to call Strano yesterday, but they must be at a race. Does that 1/4" thick washer they say may need trimming to get right fill in the gap so the bracket and top washer don't distort or is the trimming to get the lower bracket in contact with it and the bracket equally to spread the loads over more surface area?
#78
I just found this thread. Nice work, the car looks amazing! Getting it done while moving twice and changing jobs, house shopping and all....that's quite a feat. I really like the car.
I'm a little late to this one, the UMI/Strano coil overs are great (I think I have about 3,000 miles on them...give or take). I've run Koni DA's and Bilstiens (and Koni SA's on a 3rd gen, and other stuff) and this kit is as good or better than any of them. The coil overs seem to have a larger piston (monotube) and they seem to have much better "low speed" damping (damping body roll and "slow" things, this isn't "hitting bumps in the road") so the steering response is great and they don't beat you up. The ride is pleasant without the harshness you get with some setups.
I'm hoping to get out to a few autocrosses in the spring. I haven't run an event in years, but this car is at least as good as the 2002 I used to win my class in 2005.
What's next for your car?
#79
And thanks for the kind words, I'm super fortunate to have found an awesome job in an area with a low cost of living.
